valve spring question
Old Nov 21, 2007 | 05:49 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I have the standard port vortec heads ported n polished stock spring ect... Im planning on a cam swap to the luntati voodoo Lift: .504''/.525'' Duration: 276°/284° cam.. the stock springs can handle the lift at all.. they are rated for i believe 480. can anyone help me to buy new springs that will take the lift of the cam plus 1.6's?? thanks
Old Nov 21, 2007 | 09:18 AM
Re: valve spring question
First thing you need, is some machine work.... get the guides cut down so that the retainers don't hit them before they even make it to .480", and so that springs with an inner will go down over them; and since your machinist is already there, might as well get him to open up the pockets to where you can use larger diameter than stock springs too, since at that point it's basically free (all he has to do is chuck up the cutter with the larger OD).
Then, buy whatever Lunati recommends as the "premium" choice for the cam, since you're increasing the lift with the rockers.
Old Nov 21, 2007 | 09:21 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Your best choices are
-Beehives
-1.43" OD dual springs
You'd need to machine the heads for both I believe. You'll need to buy new retainers and locks for both also. Price them out and choose for yourself, I believe the 1.43" springs will be considerably cheaper, but you don't get the "frequency resonance" perks of beehives.
Old Nov 21, 2007 | 09:37 AM
I think im actually just gonna upgrade my heads.. Gonna do the Edelbrock e-tec 200's.. theyll support my cams lift with the 1.6's, theyre aluminum so im shaving weight and better airflow cause theyre 200cc compared to the 175cc stock rating on mine.. The GMPP vortecs i got are ported but not a serious job..
Old Nov 22, 2007 | 04:10 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
That cam is too small for those heads. You'll make more power with the vortecs. Its easy machine work.
Old Nov 22, 2007 | 07:37 AM
hmm alright well ill call the machine shop later on tonight when i get back from patrol.. gotta compare everything first.. cost of new heads, selling old ones, machine work, maybe new cam.. the cam isnt in yet so i cam always send it back for a different one..
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
