Distributor cap seal??
Hey I have a problem with getting moisture in my distributor cap every time the weather changes or the humidity rises. I know other people have had this problem and Im curious as to whether anyone has ever developed a remedy or solution for this? Some kind of gasket or seal for the base of the cap would probably do the trick, but when I google'd that I found nothing. Any input would be greatly appreciated, Im sure any sbc could benefit from this issue being resolved.
Thanks-Jeremy
Thanks-Jeremy
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Distributor cap seal??
That wouldn't be a solution, it would be a band-aid. What problem is moisture in the cap causing for you?
You mean like dielectric grease? That is a good idea.
Last edited by capn smokey; Nov 24, 2007 at 08:42 PM. Reason: Automerged Doublepost
Engine: 383 Carb
Transmission: 4L60
What are you talking about? Any car with a distributor will act up if there is moisture in the cap, there is no way an engine can run properly if moisture is present in the cap. Tons of people have this problem, maybe you have been living under a rock.
Engine: 383 Carb
Transmission: 4L60
Yes, standing water under the cap will cause problems, but humid weather shouldn't pose a problem. Sealing it up traps ionized gasses inside, which shortens the life of the cap. Spraying the inside of the cap lightly with a silicone spray to prevent moisture from condensing out of the air and using a vented cap to allow moisture to escape more easily instead of staying trapped inside would be better.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Car: 87 Formula
Engine: 327
The problem is pretty well known actually. There's even a note included with new Echlin brand caps sold at Napa. Sealing the cap is the exact opposite of the fix though. According to the Echlin note you should knock the screens out of the bottom plate rgarcia pictured. They say the screens plug up and then don't allow proper venting to remove the moisture.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
