Vortec Heads
Car: 1986 Camaro IROC-Z
Engine: 355ci, AFR Eliminator Heads etc...
Transmission: 700R4 Woooorked
Axle/Gears: 3:42 with Eaton LSD
Vortec Heads
Ok I currently have a pretty fresh(5k miles) Gen 1 350 in my camaro with some JUNK 882 heads on it. I put some .550 lift springs, an XE268 cam, performer intake, Holley 650DP, headers and full exhaust. My question is can I put a set of 1997 Vortec 350 heads on this block or is that a big negative?
Re: Vortec Heads
No problems I'm aware of....
THey'll need some spring work of some kind, to withstand that cam. Other than that, it's one of the best cam designs for the characteristics of the heads. Should run good. You'll need a different intake of course; get a Performer RPM.
Re: Vortec Heads
I was hoping to go with that intake actually will any performer RPM intake work or do I have to get a Vortec one?
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Vortec Heads
the vortec heads will need a spring upgrade... cheapest and best ive seen or heard is still scoggin dickey at 680$ a pair assembled for .550 l lift and modified
site is SDPC2000.com
u will need a vortec style intake so urs wont work, u will also need vortec gaskets and bolt it. thats the bar minimum
Re: Vortec Heads
Aright I like the idea of the Performer RPM but should I go with a single or a dual plane? Any opinions? Thanks
Car: 87 TA clone
Re: Vortec Heads
im not that savy with that kind of stuff.... but the intake has to be matched to the cam, the RPM range of the cam, and the type of motor ur gona be running, and the heads.
i know the single plane/dual planes like different patterns on cams, so u best bet would to call comp cams and see what they recomend with that cam, i believe single planes are more of a rever kinda of intake and like single pattern cams.... dont quote me im goin off of memory here. most street engines run dual plane i think. just get the performer RPM for vortec heads... i believe they make them
the vortec heads will give u a noticable jump in hp/tq. u will like the increases
Transmission: 4L80E/4L80E
The Performer RPM is a dual plane. That's what you want.
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: Vortec Heads
jegs sells vortecs for like $500 a set, think they have .500 lift springs....get that an intake some roller rockers and you should have something.......or you can go the ebay route
http://cgi.ebay.com/ebaymotors/SBC-I...spagenameZWDVW
Re: Vortec Heads
Arighty guys thanks for all your input, now I've got a power opinion
I'm pretty content with the cam I'm running right now whatcha think about jumpin it up a notch I was thinkin the XE274
Just a thought, anybody runnin that cam or the 284?
Just a thought, anybody runnin that cam or the 284? Joined: Feb 2007
Car: 87 TA clone
Re: Vortec Heads
i'll be running the XFI280 230/236 .567/.571 lift and 113 lobe ina few months
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: Vortec Heads
If you have the correct converter then go for it, otherwise keep the 268 and get a 3000ish converter.
Re: Vortec Heads
I'm runnin a 2600 stall converter in the Turbo 350 with 3.42 gears should I goto a 3000?
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
