Idles Extremely Rough
Old Dec 13, 2007 | 10:26 AM
Artic White's Avatar
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
My 92 occasionally will idle really rough when I first start it cold in the morning.
I did recently replace all the plugs in the car but I have no idea what could be causing this.
Old Dec 13, 2007 | 10:31 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Idles Extremely Rough
if you just did the plugs i'd check those and your wires, i've had problems with that in the past on my truck, just go through and make sure all the wires are on nicely and go from there
Old Dec 13, 2007 | 10:50 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well would wires cause it to just do it on occasion? And it's not always when it is cold.
Old Dec 13, 2007 | 11:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
They could. So could cap & rotor. Changes in humidity can affect weak components like this.
Old Dec 13, 2007 | 11:16 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I know that the cap and rotor are not too old but I think that the best thing to do would be to check the wires first and then what?
Old Dec 13, 2007 | 11:20 AM
five7kid's Avatar
A sticking EGR valve, dirty injectors.
Old Dec 13, 2007 | 05:52 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I also may have forgot to mention that the car won't pass smog either. The guy that did the smog said that it may be due to 1. The plugs or 2. The 02 sensor.
Well I have replaced the plugs and it does have more power and they didn't look too bad but I have yet to replace the oxygen sensor. Could this be a problem?
While I was driving home from school today I noticed that it would for some odd reason just spike itself up to 2000 RPM and not idle until I took it out of gear and gave it some gas. When i first started it, it idled just fine.
Also the injectors have a pretty good shaped spray so I doubt that is the problem. But I may be wrong?
Old Dec 13, 2007 | 06:24 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
check for vaccum leaks
Old Dec 13, 2007 | 06:31 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Where would I check for the vacuum leaks at?
Old Dec 13, 2007 | 09:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
anywhere there is vaccumm (hate to be obvious) just fiddle with it and you can normally find them pretty eassy, the loud sucking noise gives it away lol, and i just ran into this recently too. My car has been jerking lately and we just had rain here in az, and a temp drop, so it will just jerk whenever it feels like it, i just replaced my alternator and plugs and wires today, and its got a rough idle now, i might have moved my dist. while messin with it i dunno im gonna check it in the morning. DOnt forget the check that egr too, if its sticking you wont pass, that was my problem
Old Dec 13, 2007 | 11:08 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well this will probably sound like a stupid question but where is the EGR valve? I checked the plug wires and one of them seemed to be loose but I may as well check the EGR since it may not pass again.
Old Dec 14, 2007 | 11:21 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
ok news flash! i just had this issue and i fixed it!!!!! After i bought my car a few months ago, i set the timing to 0 where its supposed to be, then last week, i bought new plugs, wires, and an alternator cuz mine was shot. So i instailled the plugs, and it got late, so i drove home and waited on the wires, the next day i put in my alternator, ran fine, then i put in my wires and the car went to crap, rough idle, high speed miss, the whole nine yards.....frustrated out of my head i went back and thought about what the problem could be. Then it hit me, i went outside and ohmed out my old wires and the resistance was insanely high, so peicing it together i grabbed my timing gun and checked it.....13 degrees advanced!!! Then i thought over it, and becasue my old wires were, old, the resistance raised making it harder for the current to flow, so when i adjusted it, it was fine, but after putting on new wires where the resistance isnt retardedly high, it was over advanced!
I bet if you check your timing its up WAAAAYYYY past zero.
Oh and the EGR vavle its behind your throttle body, and infront of your distributor its the round thing sittin like diagnoly towards the passenger side, its fun getting it off, just make sure you have a new gasket or some rtv for when you go to put it back on
Old Dec 14, 2007 | 11:37 PM
five7kid's Avatar
No RTV on the EGR valve. It takes a special high-temp gasket.
Old Dec 15, 2007 | 03:40 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well thank you all for the suggestions. I am going to try and adjust the timing today and see where it is at. If not then I guess I will need to try and replace that oxygen sensor. Would the timing have anything to do with it smelling like it was or is running rich?
Old Dec 16, 2007 | 10:24 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
that dunno about, im used to having an air/fuel mixture screw but most of my work has been on imports, or carbed engines, but dont forget to disconnect the little plug before you time it! Its about and inch long and its on the passenger side by the firewall, its got a brown wire running to it, just disconnect it and time it, plug it back in when your done, if you dont the timing will reset after 1 drive cycle
Old Dec 16, 2007 | 12:49 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I guess I may not be looking hard enough but I do not see what plug with a brown wire you are talking about?
Old Dec 17, 2007 | 09:33 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I did find that plug after all, I just somehow overlooked it.
But I re adjusted the timing and it has more power and all the other problems have been fixed.
Old Dec 17, 2007 | 06:29 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Something to keep in mind for the future is if you have a bad throttle angle position sensor you will get a real rough idle, not wanting to run, situation too.
Old Dec 17, 2007 | 11:56 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
good deal, glad you got it fixed, but just for reference, im holding the printed alldata instructions in front of me and it says: Initial timing 6~BTDC so if the last timing doesnt work just push it to 6, but my question is when i looked under my hood, it said to time it to 0. The only problem is at zero mine runs worse....so just trust alldata from now on?
Old Dec 18, 2007 | 09:56 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I followed what the timing spec under my hood and that was 0. It ran sort of sluggish but when I unplugged that plug and retimed it and it runs great.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
IROCtometal
Sep 2, 2015 02:01 PM
