Wobbly Wheel
Old Dec 16, 2007 | 03:43 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Wobbly Wheel
Ok i fixed my wobbly tilt wheel and now my brights dont work.... anyone have clkue on how it connects in the colum?
Old Dec 16, 2007 | 04:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Wobbly Wheel
the switch is lower toward the bottom of the column, a rod runs up the left side of the column and goes to the back of the wiper switch. Must likely when you were fixing your tilt the rod wasn't put back in correctly, I had the same problem before.
Old Dec 16, 2007 | 04:45 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Wobbly Wheel
theres a little plastic rod that goes from the handle to the switch its kinda shaped like )==, if my memory serves me right, mine fell out when i had the column apart took me damn near 2 hours to fix it theres probably a bit of grease on the case that shows where it was
Old Dec 17, 2007 | 01:31 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
yeah i foudn that how does that rod fit into the equation.. i dont see where it connects to that piece
Old Dec 17, 2007 | 08:13 AM
Brennan's Avatar
Re: Wobbly Wheel
i dont think its actually connected its just held in place by the switch and the lever
Old Dec 17, 2007 | 10:23 AM
92RSZ03's Avatar
Car: 92 Heritage Camaro
Transmission: 700 R4
Re: Wobbly Wheel
The rod is held in place by the switch. If the end of the rod is already held in try making the rod longer with a pair of pliers. That way when you hit the brights there will be enough slack in the rod to click your switch
Old Dec 23, 2007 | 03:32 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
ok my brights work before this. nothign is wrong, im trying to put the darn thing back together and i cannot get the high beam rod to connect to that plastic piece or slide into it or anything. im really confused about this thing, i dont see how it is held in place.. there wasa bow shaped spring that feel out, does that fit in there somehow?
Old Dec 23, 2007 | 03:38 AM
89RsPower!'s Avatar
Re: Wobbly Wheel
it's been a while so I'm not sure without seeing a pic of it, make sure the bottom of the rod is on the switch at the base of the column..
Old Dec 23, 2007 | 09:48 AM
Brennan's Avatar
Re: Wobbly Wheel
post some pics of what you got so we can understand it better
Old Dec 23, 2007 | 01:22 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
ok will do
Old Dec 23, 2007 | 02:38 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
Ok how do all thses fit together i know that lil plasic peice slids on the cover, but where does the rod go?
Attached Thumbnails Wobbly Wheel-100_0413.jpg   Wobbly Wheel-100_0414.jpg   Wobbly Wheel-100_0415.jpg
Old Dec 25, 2007 | 12:58 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
anyone?
Old Dec 25, 2007 | 02:33 PM
89RsPower!'s Avatar
Re: Wobbly Wheel
can u get a pic of the rod? It's been a few years since I've had one apart..
Old Dec 26, 2007 | 09:52 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
the rod is in the middle pic, i might have to take another one if it isnt clear
Old Dec 26, 2007 | 03:27 PM
Brennan's Avatar
Re: Wobbly Wheel
the rod goes on the peice of the colum with the white stuff and the switch is just next to it not connected it just buts up against it as for the wiper stick thing im not sure if its connected or not
Old Dec 26, 2007 | 05:48 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
ok so b asically its just sandwiched together?
Old Dec 26, 2007 | 10:04 PM
Brennan's Avatar
Re: Wobbly Wheel
you got er pontiac
Old Dec 27, 2007 | 04:24 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
man thats gunna be a b#@(! to put back together
Old Dec 31, 2007 | 12:13 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Wobbly Wheel
thanks all who helped i got it the rod fell out of the switch which made it more confusing... now if i can get the horn working lol
Old Dec 31, 2007 | 12:15 AM
Brennan's Avatar
Re: Wobbly Wheel
if you need any help with that post it here too lol
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
FormulasOnly
Sep 6, 2015 10:42 AM
