L69
Car: 1984 camaro z28
Engine: L69 H.O
L69
I got a full gasket set for christmas. I just thought i would share the tear down and install the engine only has 61,471 miles on it.I am installing these gaskets because i blew a head gasket and had a bunch of oil leaks.Here is the progress so far. let me know if there is anything i should watch for while disassembleing this or any tricks to make things easier.
Last edited by blackandgoldl69; Dec 26, 2007 at 07:48 PM. Reason: Automerged Doublepost
Car: 84' Z28
Engine: L69
Re: L69
Are you planning on doing any other Mod ?.. CAM, Head Porting, intake ?
If you have it that far down.. I would suggest replacing the CAM, Springs, Lifter, push rods and maybe the rockers (roller rockers are great).
Keep us posted on the progress..
Engine: L69 H.O
Re: L69
I dont really plan on replacing anything just the gaskets Im only 16 and dont have alot of cash plus all the stock parts are still good. i will put up more pics as i get further along
Re: L69
My first car i bought on my 16th birthday was just like that. As for any tricks, just keep track of all your bolts and parts don't loose anything. If you come across a parts car for very cheap or free and you have room try to get it. Good luck with the car.
Engine: L69 H.O
Re: L69
Update:I just got done taking the heads off the motor.Everything looks really good.The cylinders have hardly any wear at all they look Perfect for 61,471 miles.
Last edited by blackandgoldl69; Dec 28, 2007 at 06:10 PM. Reason: Automerged Doublepost
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: L69
Now is a good time to change the O2 sensor - its a bitch when that manifold is back in the car. Get an NTK or GM unit - not Bosch.
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: L69
nows a great time to replace the valve seals. not too pricey ,well worth the money and time. be sure to check distributor gear for wear too.also be sure and take an air hose and blow out all the holes that the head bolts go in (debris,water ,coolant, grease),all will keep you from getting true torque on the head bolts upon reinstallation.oh, check oil return holes in block and heads.replace thermostat.now is the easiest time to do all this,if i think of anything else ill post again. if i can be of any help ,just ask,i have a 17 yr. old son who is learning too.89 2.8 rs camaro.we also have an 83 s-10 350 father-son project we play with,later jimmy
Engine: L69 H.O
Re: L69
Yeah i just replaced the valve seals and then we decided to tear it apart so we got a full gasket set and now im gonna replace them again beacuse they came in the kit.
I think by the time we are done it is going to turn out to be a pretty good car. For being only 16 I am lucky to have such an awsome car
Car: 84' Z28
Engine: L69
Re: L69
Well as long as your replacing the Valve seal and having the heads that far apart, I would at lease lap the valve seats.. port match the Gaskets on the intake side, polish the bowls and clean up the ports. Not much cost involved with any of these except maybe the cost of a die grinder (or something) and some grinding/polishing wheels.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: L69
Stock valvesprings should go in the trash while you have them off. After even 65,000 miles they are trash. 1.6:1 roller rockers would be a nice addition as the cam is decent in the L69 already.
Re: L69
With an engine that has that low of miles blowing a head gasket already, my first priority would be to take the heads to an honest machine shop to have them checked out. At the very least, they need to be checked with a straight edge to make sure they're not warped, and inspected for any cracks. Upgrades won't do you any good on a warped or cracked head!
Chuck84TA
Jul 15, 2016 09:05 PM
Night rider327
Oct 13, 2015 01:47 AM
