Help me Identify Please
Old Dec 27, 2007 | 12:21 PM
mr_han_solo's Avatar
Car: 1986 Camaro Coupe
Engine: 2.8L V6
Can someone help me figure what engine this is?
I do know that its a chevy v8, and I have a picture of the casting number, and I was hoping someone could tell me what model it is.
http://picasaweb.google.com/rmcole/C...70425329978928
It looks like 3951511.
Old Dec 27, 2007 | 01:26 PM
Re: Help me Identify Please
The engine in the pic looks amazingly similar to a small red X on a small square white plaque.
However, 511 is an early-model 400; 70-72. Probably has 4-bolt caps on the #2, #3, and #4 mains. Probably has 3 freeze plugs on each side of the block.
Old Dec 27, 2007 | 01:33 PM
Engine: 2.8L V6
yes it does have 4 bolt mains, and 3 freeze plugs. One of the rods is clearly bent. Probably not worth my time to tear apart and work on.
Old Dec 27, 2007 | 02:22 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
I would hold on to that if i were you, or i will trade you a 350 4bolt main block for it. How far are you from Gulfport MS?
I take it back if its what you are showing in the photo's thats not a V8.
Old Dec 27, 2007 | 02:40 PM
Engine: 2.8L V6
about 300 or 400 miles. I may just hang onto it, just figure since one of the rods is bent that the block is probably crap. Is the crank forged or cast?
Old Dec 27, 2007 | 02:44 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
in your photo gallery the 6 cylinder engine with leaves on it, is that the same engine you are pulling the # off? or is there another engine not pictured?
Old Dec 27, 2007 | 02:51 PM
Engine: 2.8L V6
no thats not the engine, i'll add the picture of the 400
http://picasaweb.google.com/rmcole/C...59185931505202
http://picasaweb.google.com/rmcole/C...59190226472514
Old Dec 27, 2007 | 03:02 PM
Yup, unmistakably a 400... it's exactly what the casting # would indicate... imagine that....
A bent rod probably means it was "hydraulic-ed"; driven through a deep puddle or something.
Not really "repairable", as such; that is, it would take ALOT of money, and the results would be less than stellar; but potentially a good foundation for building something else out of.
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
