What do i have to do to get my car into the 11's
Old Jan 4, 2008 | 03:44 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Is it possible to get my car into the 11's with 6,000 dollars?? i have a stock 1992 rs with a tbi 305 auto transmission with 72,000 miles on the clock. and the only mod being a flowmaster exhaust. and dont tell me to get a different car
Old Jan 4, 2008 | 03:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
High 11's, maybe.
A basic carb'd 383 ($3k if you watch the budget and build it yourself), built transmission w/high stall torque converter ($2k for TH700 - maybe less for TH350, but you'll need conversion equipment), very simple open exhaust ($200), gears & posi ($500), slicks ($300).
I wouldn't count on it, though. Add another $2k, much more likely.
Old Jan 4, 2008 | 03:59 PM
Car: Camaro RS
Re: What do i have to do to get my car into the 11's
i can live with 12's but i figure if i shoot for 11's i can definently make 12's
Old Jan 4, 2008 | 04:15 PM
five7kid's Avatar
That will also leave out what I would consider vitals such as subframe connectors and some means of traction improvement.
Old Jan 4, 2008 | 04:17 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Driver ability is a huge factor, do you have experience drag racing? it could be the diffrent between running 13's or 10's
Old Jan 4, 2008 | 04:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Look at nightrider'87s combo. I probably misspelled his name here, but he's got a primer black '87 Camaro with a basic mild 350 in it. I think it runs basement 12's or high 11's. It's a freak car, but a good one to emulate. Or of course mwnova66's setup(s).
Old Jan 4, 2008 | 05:17 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
A few years ago, a Mopar magazine decided to try and go 11.99 for 1,199.00, including the price of the car. They did. If you have a car and 6000.00, it'll be a snap. Just do the work yourself and stay away from high dollar race parts. You won't need them to go 11s unless MAYBE your building a ten pass every weekend dedicated drag car. You WILL need nitrous and knowledge about how to build for it, and how to use it safely and effectively. Get reading.
Old Jan 4, 2008 | 05:18 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
oh man, i felt as if you're talking to me personally haha.
don't forget to learn how to drive! i've only raced my car about 6 runs, all with huge modifications in between. that's why my times suck.
Old Jan 4, 2008 | 05:25 PM
five7kid's Avatar
MANY years ago, one of the car magazines (forget which) did it for less than that. They picked up a 500 cu inch Caddy, made a run, then started taking things off. In the end, they had all fenders & doors off, and had even cut off the roof. Totally not NHRA/IHRA legal, but they proved a point.
Forget whether or not they changed the oil or plugs before they started. . .
Old Jan 4, 2008 | 08:09 PM
Engine: tpi 305
Point taken, but the mopar was a stock bodied roadrunner with a plastic hood. Rust had gobbled up quite a bit of steel, however.
If you want an 11 sec every Sunday bracket car, ditch nitrous and spend the dough on a reliable 383/dart headed type mill. If you want an easy driving street car that can occasionally bust off an 11 at the track, just make a 350 with forged pistons, h beam rods, and a forged shaft, then stick a fogger on it. Of course you'll be running risks on driveline parts, but with an auto, the rear should survive a few passes at the track...much longer on the street where there's no bite.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
