How the #$8@ do you change motor mounts on 83 camaro
Old Jan 25, 2008 | 10:47 AM
monsooni's Avatar
Car: 83 camaro
Engine: 355 sbc 525hp
Transmission: 350 turbo built
Axle/Gears: 4.56
Nice design by gm , how do i change my stock motor mounts to solid motor mounts, looks like i have to drop the a arm. any suggestions appreciated thx
pic of my car http://s163.photobucket.com/albums/t...IMG_0206-1.jpg
Old Jan 25, 2008 | 11:02 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: How the #$8@ do you change motor mounts on 83 camaro
I actually took out my whole front suspension and got to them that way. Much easier IMO than monkeying around with a swivel through the spring...
Old Jan 25, 2008 | 11:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. A search is always a good thing here. Maybe you'll find something educational in the following link:
https://www.thirdgen.org/forums/tech...s+change+motor
JamesC
Old Jan 25, 2008 | 02:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I found a skinny-armed, teenage son motivated by wanting to race the car in the coming season came in handy for this task. . .
It would have been nice if they would have welded nuts in all the holes, or left bigger openings to get to the nuts inside the crossmember, but those things don't keep factory costs down.
I've got it to do again for the LS1 swap, and the Paragraph #1 tool above isn't available anymore. Since I'll be changing the front springs and installing poly suspension bushing while I'm at it, I plan on addressing the mounts while the a-arms are down. Really easy to get to then.
Old Jan 25, 2008 | 03:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i bought a spohn k member, called it good.
Old Feb 8, 2008 | 12:08 PM
monsooni's Avatar
Car: 83 camaro
Axle/Gears: 4.56
does your spohn k member hold up for daily driving
Old Feb 8, 2008 | 02:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yup
Old Aug 4, 2010 | 08:36 PM
smittyb83z's Avatar
Car: 4X4chevy,83Z28 soon
Engine: 350 4bolt all performance
Transmission: monster 700r4
Axle/Gears: have 2 sets not sure yet
have 83 z28 used 1/4''drive with a long extintion and swivlle on the end witch is smaller than 1/2'' drive made easier also used a skinny son definately takes two people but can be done with a little patience
took about 30 min per side driver side is a little harder if i recall on bottom front bolt socket only goes on bolt just enough to get a bite and at a slight angle if you keep good prere on it and the person turing the bolt dont get carried away its doable good luck keep wrench'n
Old Aug 4, 2010 | 08:57 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Frozer!!!
Jan 19, 2024 04:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
