No codes, but running rich
Old Jan 26, 2008 | 05:07 PM
Big Time's Avatar
What would cause a 305 TBI to run rich, yet throw no codes?
A search really didn't reveal much, other than the coolant temp sensor. I'll probably replace it, but if it's still running rich, what else could it be? The timing?
Old Jan 27, 2008 | 06:40 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: No codes, but running rich
Why do you think it's running rich?
Old Jan 27, 2008 | 07:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
How long has its been since you installed a new o2 sensor?
Old Jan 29, 2008 | 12:30 AM
Big Time's Avatar
I know it's running rich. It's been a few years since the O2 was replaced, and I considered that, but wouldn't that throw a code?
Old Jan 29, 2008 | 08:01 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
And again, what leads you to believe it is running rich? If the O2 sensor is lying to the computer, giving false lean readings, the computer will happily dump more gas, and not set any code......
Old Jan 29, 2008 | 05:42 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
keep in mind an exhaust leak near the 02 can make the o2 read leaner than actual since it can draw a small amount of fresh air inbetween exhaust pulses. this will tell the pcm lean all the time, and usually never throw a code.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
