92 RS 305 Weird Issue...
Old Feb 4, 2008 | 10:04 PM
SeanO's Avatar
Yesterday I removed the circular pipe that goes from the air intake to the exhaust manifold on the stock 305 TBI from my 1992 Camaro Rs because it had a small crack in it. I haven't replaced it yet but noticed today while I was driving my check engine light came on.
I degreased the engine three days ago and it misfired a bit and was really bogging when I hit the gas, but it dried out and is fine now. The car runs just fine now and hasn't been misfiring at all and I assume the Check Engine light came on due to engine misfiring, but now it still comes on. I have to drive the car a bit for it to come on, but eventually it will.
New spark plugs and wires are in.
Can this hole cause a vacuum in the exhaust THAT BAD so that my check engine light comes on?
The car is driving fine.
Old Feb 4, 2008 | 10:09 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: 92 RS 305 Weird Issue...
unhook the neg. battery cable, leave it off for five mins. rehook . itll let the computer reset itself ,should kill the light,later jimmy
Old Feb 4, 2008 | 11:15 PM
SeanO's Avatar
the light only comes on after I am driving a bit and then come to a stop. That's when it happened today. It's running fine the entire time, though.
Old Feb 4, 2008 | 11:22 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
sounds like you have a different problem because taking that off shouldnt do anything but stop the motor from heating up so quickly in the cold.
it doesnt even enter the exhaust its only on a sheild around the manifold and takes the hot air from it. i forgot if it goes into the intake or just warms it i forgot its been a long time.
Old Feb 5, 2008 | 08:06 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Vipershark11 is right. If the light comes on after resetting the Computer, then you must have pulled a vacumn hose off the EGK Valve or connector to the IAC sensor in the Air Cleaner. Either one will cause the light to come on after you drive a little bit. Check all vacumn hoses and connection that could have come off when you washed engine.
Old Feb 5, 2008 | 10:35 AM
SeanO's Avatar
I found when I removed my air cleaner that there was an unplugged sensor wire on the rear near the outlet for the valve cover attachment.
That probably had a lot to do with it. I'll report later on if the light comes on. The car runs beautiful, so I am leaning towards a sensor being bad.
Maybe O2 sensor too, since my cats are rattling.
Old Feb 5, 2008 | 07:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
like they said it doubtful that hose would throw the light on, it just keeps you from warming your car up for a half hour in the cold, that wire on the back of the air cleaner was probably it, but i'd still just check your vac lines to be safe lol
Old Feb 5, 2008 | 11:27 PM
Engine: LO3
an o2 sensor wouldnt be set off because of your converter rattling. the rattling just means over time the insides have broken and are just lying in there and moving around. my car had the same thing when i got it no light it was just broken so you have to replace it with a new one.
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
