socket for headbolt too big. help?
Old Feb 4, 2008 | 10:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Installing my edelbrock heads, one of the corner nuts (im running studs) threads on fine but my socket is too big to fit over the nut, the casting of the head did not give me enough room to get a socket down there. anyone run into this before? I've tried my all trade 6 point and craftsman 12point socket
Old Feb 4, 2008 | 10:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: socket for headbolt too big. help?
Try a 12 point nut? Which Edelbrock heads do you have?
Old Feb 4, 2008 | 10:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I have the victor jr's.
the nuts are what came with my ARP stud kit.
Old Feb 4, 2008 | 10:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 12 point nut would let you use a smaller socket. I don't know if they sell them separately, might want to contact ARP and ask.
Old Feb 4, 2008 | 10:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Take the head off and grind a bit of clearance?
Old Feb 4, 2008 | 10:57 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
wouldn't the outside diameter of the socket still be the same?
Old Feb 4, 2008 | 11:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the nut will be the same diameter, but the socket will be smaller.
Old Feb 4, 2008 | 11:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Like i said in my original post I tried a 6 and 12 point socket, both 5/8's and both too big?
Old Feb 4, 2008 | 11:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, because you've got 6 point nuts. 134-4001, right? You need a 12 point nut in the corners.
Old Feb 5, 2008 | 10:46 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
A 12 pt nut might require a 9/16 socket instead of the 5/8" socket. I would go to your favorite nut & bolt store and see if they have a smaller nut (12 pt or even 6 pt) having the same stud thread.
Old Feb 5, 2008 | 06:42 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Are you using 1/2 drive sockets or 3/8 ? Impact sockets or chrome?
I think the thinnest wall socket is 3/8 chrome.
Old Feb 5, 2008 | 08:13 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
just a 3/8 chrome...
Old Feb 5, 2008 | 08:34 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
hey traviz, go to sears ,they have thin wall sockets just for tight places like this. what aperion is saying is they make nuts that have the same size hole in the center,but a smaller size on the outside, this way you can use a smaller socket.later jimmy
Old Feb 5, 2008 | 08:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thank you for the tip and the clarification 1fastam. I did look around today at a few places, but seems 12 point nuts don't exist. I will check out sears tomorrow for this awesome socket
Old Feb 5, 2008 | 09:39 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
tthe sears number for the socket is sears item #00943314000,model#43314. price $3.99 hth ,later jimmy
Old Feb 5, 2008 | 11:40 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I had the same problem with my AFR Heads and with arp 12 point 1/2 inch socket head.
I was using sears 3/8 drive socket and it was binding on the valve spring shims on the corner bolt up front.
I turned the socket down about .030 and it fit fine.
Fronzizzle
Feb 9, 2017 09:31 AM
Drone358
Sep 28, 2015 04:55 PM
ramicio
Sep 28, 2015 01:18 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
roysatikas
Sep 22, 2015 08:15 PM
