Why does my car shift at ~8k?
Old Feb 5, 2008 | 09:34 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
http://www.youtube.com/watch?v=BJF76JhtP-E
a little video might be hard to see but you see the stock tachometer go to 7k which is the max and then the aftermarket tach goes to 8k which you can't see. My old camaro shifted at like 6.5k why do you think it is shifting so high?
Old Feb 5, 2008 | 09:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Why does my car shift at ~8k?
I am going to make the guess that you have both tachs in 4 cylinder mode. That honestly didn't sound like it would up any more than 4,000-4,500 rpm. I tried once to rev a 350 TBI in a truck to 6,000 rpm. Valve float and air flow restriction held the engine to no more than 5,300 rpm, foot on the floor in first gear.
Old Feb 5, 2008 | 09:38 PM
robster66's Avatar
Engine: 305 T.B.I.
aftermarket is so I could get a closer reading so it matches my stock but I never touched the stock one
Old Feb 5, 2008 | 09:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I can tell you that it is nothing near 8K. This engine is wound up pretty tight and its only turning 6,700 when the rev-limiter kicks in.
http://youtube.com/watch?v=3u2CmNuMsBc
Old Feb 5, 2008 | 09:47 PM
robster66's Avatar
Engine: 305 T.B.I.
my car doesn't have a rev limiter
Old Feb 5, 2008 | 11:30 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you were no where near 7~8000 RPM.
with the gear you have you would have been well over 100 MPH on the 2-3 shift, im guessing probably close to 140~150 or so, but im not going to do the math to figure it out
your stock tach needs to be fixed, set the aftermarket tach to 8 cylinders.
Old Feb 5, 2008 | 11:52 PM
EvilCartman's Avatar
Car: '82 Z28
Agreed, no where near 7-8k rpm I've only had mine up to 7500 rpm before the limiter kicked in (msd) and the engine was singing.
Old Feb 6, 2008 | 05:24 AM
robster66's Avatar
Engine: 305 T.B.I.
The instructions for the aftermarket tach told me to set it to 6 cylinders.
Old Feb 6, 2008 | 06:49 AM
You should have read the entire instruction.
It tells you, for a 6-cylinder motor, set the switch to 6 cylinders.
It also tells you, for a 4-cylinder motor, set it to 4; and for one with 8 cylinders, set it to {drum roll please} 8.
Your stock tach is wrong, as they usually are, it reads WAY high; and your other is inproperly installed. Fix the installation of the one, and ignore or replace the other.
Old Feb 6, 2008 | 11:52 AM
robster66's Avatar
Engine: 305 T.B.I.
actually for the aftermarket tach like I just said tells you to set it to 6. I did read the directions but 6 was way off from the stock tach so I set it to 4. I mean if you read my post instead of assuming you would have knew that already
Old Feb 6, 2008 | 12:02 PM
No, it doesn't.
It says, like EVERY other aftermarket tach, to set the switch to match the number of cyls the engine actually has. There's 3 sparks per rev in a 6-cyl, and 4 sparks per rev in a 8-cyl; the tach has to be told how which constant to use. That's what the switch is for, in the first place.
Believe it. No point in arguing.
Set the switch to "8", ignore the defective stock tach, and move on.
Nothing else that you have posted, or could ever POSSIBLY post, will change how tachs work (or don't.... like your stock one).
Old Feb 6, 2008 | 12:07 PM
robster66's Avatar
Engine: 305 T.B.I.
Im just telling you what I have in front of me that says it.
Old Feb 6, 2008 | 12:16 PM
philip052374's Avatar
Car: 91rs
Engine: 6.0
Transmission: 4l60e/3600 vig stall
Axle/Gears: 3.73 9 bolt
well, do you have a 6 cylinder? does the new tach have a switch that says 8? dude, this is common sense. and by the way, there is absolutely no way your motor was turning 8,000 rpm. sounded like 4k at most.
Old Feb 6, 2008 | 12:18 PM
robster66's Avatar
Engine: 305 T.B.I.
it is an 8 but in the booklet it says for 8 cylinders to put to 6
Old Feb 6, 2008 | 12:24 PM
Then it's wrong. A typo or whatever.
Put it at 8 for a V8.
BELIEVE IT.
Old Feb 6, 2008 | 09:04 PM
robster66's Avatar
Engine: 305 T.B.I.
it idles at 750 the tach says and screams at 4k
Old Feb 7, 2008 | 12:30 AM
Car: '82 Z28
Read this very carefully. If you have an 8 cylinder engine, set the tach to 8 cylinders. Then, grab a lighter and the instructions, set the instructions on fire.
btw, here's an in-car video a friend took while riding with me at the strip. I was shifting at about 7,000 rpm, the burnout I'm guessing was between 6,000 and 6,500.
Old Feb 7, 2008 | 12:50 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
never mind those other guys, keep it at 6 and tell everyone the reason you turn so many rpms at hiway speeds is you have 6:13 gears.
Better yet change it to 4, you could have a real bad azz car then.
Prove it to yourself, hook up a scan tool and see what RMPs the ecm is seeing.
Shifting at 8k with a tbi 305
Old Feb 7, 2008 | 07:59 AM
robster66's Avatar
Engine: 305 T.B.I.
Well I put it to 8 and it shifts at 4k most.
Old Feb 7, 2008 | 08:12 AM
Sounds about right... that's about what those usually do.
Old Feb 7, 2008 | 08:15 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
if you are still secong guessing yourself call yhe manufaturer of the tach
Old Feb 7, 2008 | 08:25 AM
robster66's Avatar
Engine: 305 T.B.I.
It will be screaming at 4k. I guess I will have to get a tool to find out the real rpms and match it with that.
Old Feb 7, 2008 | 08:29 AM
screaming at 4k
Yeah, for a TBI 305, that's about right... that's what those usually do.
Sounds like you're good to go, and you're getting THE TRUTH from your new tach now.
Old Feb 7, 2008 | 09:02 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
this must be your first v8. You had a honda before this car didn't you?
If you had ever driven a car with a stock v8, you'd know that 4 thousand is way up there for it. I'd hate to see you in a diesel....
Old Feb 7, 2008 | 09:05 AM
robster66's Avatar
Engine: 305 T.B.I.
nah I have a 94 blazer and I had a 88 chevy camaro 6cyl which shifted at 5.5k
Old Feb 7, 2008 | 02:18 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
was it really that difficult to flick that switch to 8? doesn't it just make sense now?
Old Feb 7, 2008 | 04:38 PM
robster66's Avatar
Engine: 305 T.B.I.
no because I never thought a cars redline would be so low
Old Feb 7, 2008 | 04:55 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
i'm sorry but that was a really dumb thing to say. common sense should have said something when you read the directions
Last edited by onebad89RS; Feb 7, 2008 at 09:01 PM. Reason: correcting my insulting post
Old Feb 7, 2008 | 05:57 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Damn, this whole thread had me rolling. Pretty funny, your car is a V8, ur tach had a switch for 8 cylinders and you put it on 4. Even if the instructions were a misprint, you should still acknowledge that 8 goes for V8. 6 for the V6 and so on. I know this was all already mentioned but, good stuff.
Old Feb 7, 2008 | 06:22 PM
mxcrazed's Avatar
Engine: None
Transmission: none
the car's red line does not matter it is geared to operate under those conditions
Old Feb 7, 2008 | 07:15 PM
C'mon guys, let's not rag on him any more....
He manned up to his mistake, even admitted it on the Internet, and now he's fixed it. I doubt any of the rest of us would like for people to keep kicking us even after we fessed up like that, let's not do it to him either.
Even though it was kind of weird for awhile.
But yeah, the whole experience of buying a supposedly "performance" car and getting a LG4 or L03, has gotta be a bit of a surprise for somebody that wasn't around to remember that at the time, it was tough to do much better than that.
Old Feb 7, 2008 | 08:06 PM
mxcrazed's Avatar
Engine: None
Transmission: none
i wasn't kicking him that last time just explaining why a car would have such a low red line but i agree with you sofa he's had enough
Old Feb 7, 2008 | 08:31 PM
robster66's Avatar
Engine: 305 T.B.I.
yea well I would expect the directions to be right after all. I am learning about cars why do you guys have to be such ******? I know it's a freakin 8cylinder but it still said to set it to a 6. I don't normally use directions but what do you want from me? The first aftermarket tach I installed get over yourselves.
Old Feb 7, 2008 | 09:20 PM
DENN_SHAH's Avatar
robster66, your not the first to make this mistake, & you won't be the last by a long shot.
something to remember, sometimes the directions are wrong. there is no telling how many times they were translated from one language to another.
this may help you repair your factory tach,
https://www.thirdgen.org/forums/elec...=1#post2836660
Old Feb 7, 2008 | 09:25 PM
robster66's Avatar
Engine: 305 T.B.I.
Thanks for the positive info it's not like I randomly just set it to 6 or 4 when I KNOW my car is an 8 cylinder. I did what it told me to do
Old Feb 7, 2008 | 09:49 PM
82Five-O's Avatar
Car: 82 Sport coupe
Glad you got it fixed bro!!
Old Feb 7, 2008 | 10:20 PM
mxcrazed's Avatar
Engine: None
Transmission: none
just a tip next time it says moderator or senior member under the user name its probably good information
Old Feb 8, 2008 | 03:17 AM
Car: 1991 Camaro RS
I wasn't ragging on you pal, didn't mean no harm, just thought this whole thread was a bit funny. Hope you enjoy the Camaro.
Old Feb 8, 2008 | 07:49 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
robster66: Its the internet... Gotta have thick skin sometimes! Most of the guys that you think are being "******" are just having some fun...and most of them would gladly help you out in the future. You know...if you were an X-Box 360 genius, and someone came onto an X-Box 360 forum and asked how to put a game in... Might get some ribbing haha.
Glad to hear you worked it out. Learning about your car is the fun part!!! Now go build yourself a motor to spin to 7500 and have some fun!!!
J.
Old Feb 8, 2008 | 10:25 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Agreed. Now if you think shifting at 4k is not so mean. Open up ur exhaust and have some fun.
Old Feb 8, 2008 | 05:02 PM
robster66's Avatar
Engine: 305 T.B.I.
I can't go open headers on this car I will be pulled over eventually. I have had a cop follow me in my 6cyl with open headers lol.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
