cam and heads
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
cam and heads
i am looking into buying new heads and a camshaft
but dont know what the best combo for my car would be
its is a 1991 5.7 l98
so any opinions would help i am looking for the best power for the cheapest
Re: cam and heads
If you intend to keep the TPI, TF 195s and the Comp "502" grind. If you have headers, the "503".
Re: cam and heads
I say if you keep the TPI, the comp cam XFI-280 the power band starts at 2000 but the long runners still would give you good low end torque plus it streetable, for as heads, any nice set of alluminum heads with 2.02 1.60 valves. thre are many to choose from depends on how deep your pockets are.
Re: cam and heads
I AM GETTING READY FOR CAM SELECTION-I AM RUNNING A 350 TWIN TURBO WITH A TPI SIAMEASED RUNNERS AND A BIG MOUTH MANIFOLD MY HEADS ARE 2.02-1.60 AND I AM LOOKING AT A ROLLER SETUP-LOOKING AT A 2500 TO I NEED TO REPLACE SOME PARTS IT JUST BLEW RPM RANGE ANY CAM SUGGESTIONS WILL BE HELPFUL THE BOOST IS GOING TO BE AT A LOW 8 TO 10 POUNDS
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: cam and heads
speaking of turbo what brand did you buy and how is it even on low boost
and do you have any pictures of it
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: cam and heads
Best of luck to ya! Trending Topics
