2nd oil pan gasket still leaks
Old Feb 14, 2008 | 10:01 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
i just put in a new oil pan gasket the felpro all rubber blue one and i got the same leaks from the same front and rear part of the gasket i did not use any silicone on the gasket not even in the corners, i heard from numerous sources to put them on dry... the engine use to use cork gaskets and silicon, but was never leaking befor.. is it possible my pan is just simply warpped? id rather go get one than have to redo it later cuz the leak continues.
Old Feb 14, 2008 | 10:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 2nd oil pan gasket still leaks
What year is your block?
Old Feb 14, 2008 | 10:07 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I don't know about the "Correctness" of it all.... but, I use silicon sealer even with the "rubber" (actually, I think it is neoprene??) gaskets. even the one piece fellers.... a little dab in the corners (both sides of the timing cover, and both sides of the rear main.) Never had any problems.
Since it seems you get to pull the pan again anyway..... find a nice flat surface you can lay you pan on (on the mounting rail) Kitchen table works great, but, bear in mind that you will quite likely **** off your mom, wife, S.O. of any other nature...... I always tried to do this, and have the mess cleaned up, before she got home...... anyway, with the pan sitting upside down on the table, it is relatively easy to see if the mating surface is warped......
Old Feb 14, 2008 | 10:17 PM
fychelio's Avatar
Axle/Gears: ????
its an early model one like 70's id assume and from what i got off the engine code
when i cleaned it it seems flat i put it on the side wall of the tube.. im more inclined to think its the round lips of the pan sinde it keeps leaking from dead center.. but i used no silicone in the corners and even the little print out the gasket came with says to use it lol... ill try that and for 40 bucks might as well change the pan too. thanks dude
Old Feb 14, 2008 | 10:24 PM
fychelio's Avatar
Axle/Gears: ????
but apeiron what did u have in mind... the more insight the better in this case...
Old Feb 14, 2008 | 11:37 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
where exactly is your leaking? let me guess.....in the very center at the rear main between the gasket and the pan?
Old Feb 15, 2008 | 12:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is your gasket for a thick or a thin seal pan?
Old Feb 15, 2008 | 11:52 AM
B1qwkbird's Avatar
Car: 83 T/A
Engine: ZZ4 350
Axle/Gears: 7.5 inch 3.23 gears, for now
Are you 100% sure it's not the rear main and the timing cover seal?? I'm a mechanic for a living and it seems that 90% of the time, it's not the pan but rather the seals with a leak such as yours. Especially since the most likely place for the pan to leak is at the corners where everything comes together. Also....the thick or thin seal gasket is VERY important.
Old Feb 15, 2008 | 02:29 PM
fychelio's Avatar
Axle/Gears: ????
its the thick blue gasket its pretty thick.
yes tht is exactly where its leaking
yea im pretty sure its not the seals the engine was dry and newly rebuilt until i decided to switch the oil pan gasket to c if i had two or four bolt mains
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
