oil out of pushrod tubes
Car: 88 GTA "Cocaine"
Engine: 350 tpi
why does the oil only come out of two of the pushrods out the rockers
it tends to even out as motor warms up but the stream is extreame
the pushrods are clean by the way-always soak in gas and blow out
Re: oil out of pushrod tubes
Luck of the draw.
The "vent" holes in those 2 rockers happen to line up with the hole in the end of the push rod; the others don't.
It doesn't make the slightest bit of difference.
Engine: 350 tpi
sometimes I am a bit picky
I dont think its a bad thing
sofa I like it when you answer my treads, thank you
I know you are quite picky yourself
I am indeed!!!!
I'm even picky about what I should be picky about.
That way, I don't waste too much of my inherent ****-ness on things that don't matter, but rather, I try to focus it where it can do the most good.That's just sick.... being **** about how to properly be ****......
call the nice young men in their clean white coats NOW please. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
