Lost my key to my Car!!!
Car: 85 Trans Am
Engine: 5.0
Ok so i have an 85 t/a and I cant remember where I put my key. What should I do?? I guess call a lock smith and they can come?? The car is unlocked. Its been sitting for a while so I want to start fixing it up.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Lost my key to my Car!!!
A dealer might be able to make you one from the VIN#.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
A mobile lock smith service is one option. If it's a key with a chip, the most reliable way of getting a new replacement key is to take your vin number to the local GM dealer, they can cut you a new key. If you go that route, might also take your registration in case they ask you to prove it's your car.
Good luck
Good luck
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
his car is an 85 i'm pretty sure thats pre vats so no sensor. Atleast my 85 z28 doesn't have a sensor but my 91 does
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Look for the assembly line build sheet inside the car. They're usually under the under the seats, carpet or behind the door panel. The key codes will be on that.
If you have the necessary tools to remove the steering wheel and lock collar you can take out the ignition lock cylinder and read the key code stamped on the side of it.
I think an '85 will be too old for the dealer to look up the key codes with the VIN#. I'm pretty sure the GM DealerWorld computer system only goes back to 1990.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i just replaced the ignition tumbler with a new one, with a new key.
Engine: 5.7/5.0
i replaced my ignition not too long ago. Was about 20 dollars from the local autozone. That may be the cheaper route
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
I am a "part time locksmith". If you do not want to try this yourself I would go to an auto supply store and buy a new ignition switch with keys, then, find a locksmith to replace it. It can be frustrating to replace. You will save yourself some money buying it yourself, and you will not have to buy a couple of tools needed to do the job easily and correctly. I have not had to change mine but I do have the right tools. It should only cost mileage and labor, about 1 hour. $35 to $50 per hour. I know it is not cheap, but, if he messes up you can have him/her make it right. Randy
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
if you have a AAA membership you can call them and they'll send someone to your house to make a new set for free. i've done this before with my daily driver.
for the imput .
