no wonder it ran 15's
Old Mar 25, 2008 | 01:55 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
this design flat out sucks for performance
this on the otherhand!! my patriots below
Old Mar 25, 2008 | 02:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: no wonder it ran 15's
What was the original head?
Nice choice on cam
Old Mar 25, 2008 | 02:33 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
they are gm 10110810 castings
high swirl ports. lots of bottom end
thanks. you dont think its to small for my combo 383 with 10.9 compression estimated
Old Mar 25, 2008 | 02:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Ah. I didn't see the swirl ramp. I just figured a bit of die grinder work would get rid of that NASTY pushrod pinch.
It'll be a pretty mild cam in that engine. Dynamic CR will be fairly high. With aluminum heads you're right at the max i'd say.
Old Mar 25, 2008 | 03:11 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
what cam would be good to drop the dcr and not be to big of a tuning issue
Old Mar 25, 2008 | 07:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
That's not how you fix too much CR. There's no way to "win" there.
With AL heads, port injection, and good quench (right?) you should be ok. Just make sure you have a decent stall speed, and don't lug it around in overdrive at low speed. Keep an eye on how you program in your tune, ie not too much timing at low RPM high load, good fueling curve, etc.
If you intend on running nitrous i'd step up gently to that 150HP shot. Perhaps use race fuel for the nitrous usage.
Old Mar 25, 2008 | 08:22 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
HOLY CRAP!!!
If they weren't all the way in Texas, I'd bring my sledge-hammer over and personally pound them into bits for you.
Pictures like that make us that have ported heads just shudder...
(it's a shame they don't fit mustangs, or I would suggest selling them)
Please tell me you didn't have the 383 trying to suck thru them ...the horror.
Old Mar 25, 2008 | 09:30 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
no they were on a virgin 350 i freshened up so i could continue to get to work didnt pay to much attention to what they were until i realized it might as well still had the 305 in it!
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Linson
Oct 1, 2015 09:50 PM
