Loose Brake Pads maybe?
Car: 92 Camaro RS
Axle/Gears: Stock
Hey guys,
My left front wheel keeps making a slight rubbing noise (metal on metal)....my best guess is that it is a loose break pad.
The sound is a very light scrape like a pad resting on the disc, versus actual "binding" which would be tight.
(it stops every time I tap the brakes, but comes back 10 seconds later)
I will prob have the wheel off this weekend to look...
Any ideas what else it may be and any signs of wear in particular I should be looking for while I am there?
92 Camaro RS (305 TBI) - Stock
Transmission: 4L80E/4L80E
Probably your wear indicator telling you to replace the pads before the rotors get chewed up.
Re: Loose Brake Pads maybe?
Could well be the wear indicator.
If that's OK, and the little "ears" on the outboard pad aren't bent over to make them grab onto the caliper, bend them. A BFH works well.
It can still be.
All it is, is a little "flag" of metal riveted onto the end of the one pad. If it gets bent the wrong way (like, if the box they were in got dropped somewhere along the line, or something) it can very easily be up against the rotor and making its annoying racket, from the minute the pads are first installed.
It's definitely worth a look.
Car: 92 Camaro RS
Axle/Gears: Stock
It can still be.
PS - any tips or tricks for getting the calipers off etc?
or are they pretty much as you would expect?
(eg, bolts tight as f*ck but simple other than that)
Last edited by British Rich; Mar 31, 2008 at 02:35 PM. Reason: Automerged Doublepost
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
If you just replaced the break shoes 6 months ago, then the calipers should come off pretty easily.
Car: 92 Camaro RS
Axle/Gears: Stock
makes sense! LOL
(I didn't do them personally hence why I forgot! This is why I need you peeps! LOL)
Right; and the bolts shouldn't be all that tight, anyway. But you know how things that should be are... namely, however they are, instead of how they should be.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
3/8" allen key (or was it 5/16"?) is needed for the caliper bolts. Remove wheels, remove the caliper bolts, and give the calipers a few love taps from your itty bitty hammer (not necessary to bring out the BFH), and it'll come right off.
I think I'd remove the wheel, and then look everything over very carefully before removing anything else.
Night rider327
Sep 2, 2015 04:17 AM
