Annoying Oil Leak
Old Apr 10, 2008 | 02:26 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
Annoying Oil Leak
My car leaks oil somewhere near the back of the engine.
As the car warms you can see the smoke and the burning oil smell.
The underside of the engine is kinda oily. It is only in the back, near the firewall... as far as the oily smoke.
Also at idle there is white smoke, and i will assume its not ( and hope not) it being a head gasket. Could the exhaust smoke be cause by this oil leak?
Thanks!
Oh yeah the oil smoke smell can be smelt inside the car.
Old Apr 10, 2008 | 02:34 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Annoying Oil Leak
could be a head gasket or a rear main seal. I just did a rear main seal on my friends 350 in his full size van cause it was leaking oil all over the back of the motor. Does it blow smoke out the exhaust as well at engine startup? Gives us some more details if you can.
Old Apr 10, 2008 | 02:36 PM
Car: 1988 Camaro SC
Engine: 2.8v6
There was significant oil on the rear spark plug and wire on the leaking side...
And not sure about on the other side...
The smoke occurs on the drivers side...
Old Apr 10, 2008 | 02:40 PM
Engine: Vortec 357
sounds more like a head gasket to me.
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
valve cover seal. thats the only place that it could drip on the back of the engine, and drip down onto the spark plugs, wires and exhaust. your rear main would only show on the bottom rear of the engine, a blown head gasket wouldn't be able to drip up onto the spark plug wires, etc.
Replace those seals, wipe down the engine, and see where that leaves you.
Old Apr 10, 2008 | 02:58 PM
Engine: Vortec 357
I just thought of that as i rolled back under my car... it could def. be that also
(im on my labtop in the barn changing the oil on my as we speak, TGO gives me something to do while i wait for it to drain...) lol
Old Apr 10, 2008 | 03:54 PM
Car: 1988 Camaro SC
Engine: 2.8v6
valve cover gaskets = valve cover seal?
Old Apr 10, 2008 | 04:25 PM
thunder85's Avatar
Engine: 5.7L w/hsr
exactly. get a pair of the rubberized type... seal better and longer than the cork or paper like ones. i would replace both if i were you... if one is bad, the other one is probably getting there.
Old Apr 10, 2008 | 06:00 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Is it near the top? Check to make sure the distributor seal is intact. Not sure, but it could also be a bad oil sending unit. Both very easy fixes and both will drip oil on a hot engine.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
