Sparkplug recommendation please
Old Apr 12, 2008 | 09:49 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Hi!
Ive installad an MSD 8366 Distributor & MSD Blastercoil (48.000V) and MSD 8.5mm Super conductor wires. and Brand new AC Delco RJ45TS sparkplugs.
What gap shall I have on that ? right now im running in stock gap = 035"
I heard like 045" would be good ? shall I run with that or do you guys have any other recommentaions ?
And Sparkplug, I can use the RJ45TS (stock plugs) or shall I have any others ? and IF so, please give me some info about them.. There is no danger of running on the Delco ones ?! or ?!
Old Apr 12, 2008 | 11:57 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Sparkplug recommendation please
The wider the gap the higher the volts to jump across.
Old carb type coils 30-50,000 volts .035
HEI 70,000 volts .045-.060
New coil packs can kill you .080
anything from .040 to .060 or so.
BTW lawn mowers .025
GM runs Delco all the time. It is OEM stock.
The R in the part number, means it is a resister plug and it takes more volts to fire.
Old Apr 12, 2008 | 12:10 PM
Theking's Avatar
Car: 1989 IROC-Z
So if I use 045" on my RJ45TS sparkplugs will do fine then ?
No need to change to another sparkplug ?
Infested
May 22, 2018 11:56 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
pm_
Oct 16, 2002 12:33 PM
Mike86Z28
May 27, 2002 05:57 PM
WaynesRS
Feb 12, 2002 01:06 PM
