I cant figuer this out
Old Apr 21, 2008 | 04:57 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Thanks guys,
The IAC is working and the car still wont start! Every single part is less than six months old????
The car ran, I adjusted timing and fuel pressure shut it off for the night and it has not started since?
It has fuel it has spark at the plugs
When you turn it over it sounds like it wants to hit for a second and then just cranks
WHAT AM I MISSING?
thx
Jeff
Old Apr 21, 2008 | 05:24 PM
Nsomnia's Avatar
Re: I cant figuer this out
You need spark (at the right time), fuel, and air.
Make sure the timing isnt off.
Old Apr 22, 2008 | 05:52 PM
jjlabinski's Avatar
Engine: shinny 350
How would the timing be that far out when the car was running last time I shut it down?
thx
jeff
Old Apr 22, 2008 | 05:56 PM
Nsomnia's Avatar
Thats why
Old Apr 22, 2008 | 06:00 PM
jjlabinski's Avatar
Engine: shinny 350
I will try and put the timing back where it was which was about 25 degrees advanced. that is where the car would run and I knew it wasnt right so I backed it down to about 8 degrees. I am heading out to the shop to put the distributor back in the engine I removed it to inspect the gear.
I have a suspicion the cam timing is off
thank you
Jeff
Old Apr 22, 2008 | 06:08 PM
Nsomnia's Avatar
25 degrees initial doesnt sound right at all. It should be 8-12 degrees initial, usually 10, itll probly run from -5 up to 15 or more degrees.
Did you remove the cam? Unless your timing chain magically stretched overnight a massive amount it shouldntve moved.
Old Apr 22, 2008 | 07:21 PM
jjlabinski's Avatar
Engine: shinny 350
Dizzy is back in and nothing! When I checked the timing with the EST disconnected my timing at 1100 rpm was 21 degrees.
It is a new engine with about two hrs on it. something went south to cause this I am on my second ECM maybe it took a crap again...why
thx
jeff
Old Apr 23, 2008 | 02:53 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Ok, before you adjusted the timing it was 21deg at 1100 rpm. That would be fine depending on the weights and springs in your dizzy, at 1100rpm your mechanical advance is already kicking in. Your initial advance should be set at 500-800rpm depending on your transmision. As long as your not going over 40deg total with all your timing in or getting detonation. I would suggest pulling out the dizzy and starting over, bring the engine to tdc and set the dizzy in with the rotor pointed to #1 cylinder. Put cap and wires back on and try starting. If it backfires you are 180 out. I like to mark my wires and cap with witeout or paint marker to make removals easy. How are you checking the timing if its not running?
Old Apr 23, 2008 | 02:58 PM
Stephen's Avatar
Car: 87 GTA
Carb'd or FI? Your profile says 84, but o mention of what engine. If FI, did you disconnect the plug on the firewall?
Old Apr 23, 2008 | 05:49 PM
jjlabinski's Avatar
Engine: shinny 350
Yeah,TPI engine. yes the EST was disconnected.
Looks like I gota pull the engine. . . .ugh
jeff
jay7199
Aug 17, 2014 10:03 AM
1986_iroc_z28
Nov 22, 2013 08:36 PM
iceblast
Members Firebirds
Feb 13, 2012 03:04 PM
kndarwin
Oct 10, 2009 02:57 PM
