safe 305 bore????
Old Apr 28, 2008 | 07:02 PM
jeepboy180's Avatar
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
safe 305 bore????
whats the most you can safely bore a 305???
Old Apr 28, 2008 | 07:23 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: safe 305 bore????
I believe it would be 60 over would be the max
Old Apr 28, 2008 | 07:26 PM
jeepboy180's Avatar
Engine: 305ci TBI
okay, how would I go about doin the math, to figure out what that would make it in cubic inches????
Old Apr 28, 2008 | 07:44 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
My machine shop goes .080 over on 87+ 350s all the time, a 305 should be just as capable if not more since the cylinders are further apart.
Old Apr 28, 2008 | 07:48 PM
jeepboy180's Avatar
Engine: 305ci TBI
Well I was wondering if I could go,.... Oh say, well I'd like to get like a 307 bore, but I didnt know the blocks limits. SO how bout it?????
Old Apr 28, 2008 | 08:19 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
A rough guess would be .020 over bore, there would be no power gain really, 2 cubes would be 1.6-2.2 hp depending on parts, i hope power isnt a goal.
Old Apr 28, 2008 | 10:29 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
You can go out to 4.001" by spending $50 on a 350 block...
Old Apr 28, 2008 | 11:47 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Word.
Old Apr 28, 2008 | 11:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
.080" ? Yea, ok now go find pistons to fit that
.060" is about the max, and i'd want to sonic check that. That makes it a 310CID engine. You don't BORE an engine to get more cubes for HP. Boring it doesn't give enough cubes to make a difference. Stroking it, yes. But still, a 305 isn't a good core to start with. Stroke (and bore if necessary) a 350, and then you're cooking with gas.
Word.
Old Apr 29, 2008 | 11:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
How far apart the cylinder walls are is irrelevant. How thick the cylinder walls are is relevant.
Just because the cylinder walls are farther apart doesn't mean they're thicker. They typically shoot for the same thickness. Due to casting core shift, they might be thinner.
Regardless, anything over .030" and you're taking a risk.
And, any consideration of boring a 305 block could be considered a poor use of rebuild dollars, and certainly is a poor use of performance dollars.
Old Apr 29, 2008 | 12:15 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yhey are out there, not too much performance but stock replacement, yea.
Just what i have heardm 350 walls are thicker than a 400 but a 305 should be the same as the 350.
Old Nov 20, 2013 | 11:21 PM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
Old Nov 21, 2013 | 04:49 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Well I believe the OP should know the limits of the 305 before dumping a bunch of money into it and being disappointed later.
Old Nov 21, 2013 | 07:01 AM
1gary's Avatar
http://www.wallaceracing.com/cid.php
Guys talk about "their" adventure of a bore size of .080 which is unnecessarily high risk when considering 305's blocks are so cheap to get or free.
Still even with a enlarged bore size,the limited factor is the bore shrouding the intake valve and it not flowing well.Maybe one reason why the turbo 305's are so popular.Yet the guys running 305's in super stock drag racing are very,very,stout.But that is major money spent on them.
I am all about guys wanting to do things their own way as all as they know what issues they are going to have in front of them.
Old Nov 21, 2013 | 09:06 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Ross pistons. They make all kinds of pistons. They even made pistons for a couple of old 1920's Miller Indy race engines.
Yea, I wouldn't start boring a block without knowing the wall thickness first. I don't remember the casting numbers off hand but there were a few 70's castings that were really bad.
Old Nov 21, 2013 | 05:54 PM
KR81's Avatar
Originally Posted by 1986 305 RS
I want to choke people and their 350 comments when people have questions about their 305.....learn to read!!! Some people like being the minority.....seems to me like everybody and their mother has 350s.....and they can keep them.....
Word
Old Nov 21, 2013 | 06:20 PM
five7kid's Avatar
I want to choke people and their 350 comments...
I want to choke people who resurrect 5-1/2 year old threads and post on them like it's a current discussion...
The OP hasn't posted on TGO for 4-1/2 years.
The "Don't tell me to get a 350" stuff gets old, too. The OP never said he didn't want a 350, he asked how much he could bore a 305. We never got to the bottom of what he was trying to do before he quit posting.
Don't be presumptuous. In this case, it wasn't presumptuous to suggest getting a 350 block rather than spending money boring a 305 block.
Old Nov 22, 2013 | 06:02 AM
1gary's Avatar
Learn to read??.Yep.Like dates and stuff??.57,should be a -1 post count on his user.........................
Old Nov 22, 2013 | 06:48 AM
Edwardgp's Avatar
Engine: 454-350
OMG digging up bones again!!!!!!!!!!!!!
Jake_92RS
Jan 28, 2020 10:37 PM
Grant2k
Jul 10, 2018 04:01 PM
angel2794
Sep 8, 2015 06:22 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
NinjaNife
Aug 23, 2015 11:49 AM
