Hard to start after a drive
Old May 5, 2008 | 04:58 AM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Basically what the title says...it starts fine when its cold and if it has sat for 15-20 mins but if I take it to the store then come back out (if its warmed up) it turns over like it has a dead battery it might roll over once real slow or it will make half a roll or something like that but let it sit a sec and it will fire up. Some one told me that my headers might be the problem and that its heating up the starter and that when it sits for a bit it has time to cool off...what do you guy's think?
Old May 5, 2008 | 06:30 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Hard to start after a drive
How close are the headers to the starter? Did the problem start after the installation of the headers? If so, you might need to install a heat sheild. If not, the starter might be getting weak and the extra heat from the headers so near might accentuate the problem.
Old May 5, 2008 | 06:52 AM
AC's Avatar
AC
Car: Used to drive a camaro
Welcome to "Heat Soak" my friend. Common issue when having headers. Two maybe 3 possible solutions. Heat shield as mentioned, thermal blanket wrap, or a mini starter are all possibles. The other possible is just let the car cool off an hour or so everytime you take a drive (that idea doesn't sound too good does it?).
Old May 5, 2008 | 04:05 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
The headers were on it when I got it so dunno there....mini starter sounds like an option tho, not really keen on wrapping anything around it but might try a heat shield. thanks for the info guys
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
