2 or 4 bolt main motor?
Old May 9, 2008 | 04:14 PM
89 thumper iroc's Avatar
I have a 89 iroc Z 5.7 tpi 700 trans,all stock.Were the 350 blocks 2 or 4 bolt mains,and is there anyway to tell with the motor in the car?I cant get to the casting # there's too much in the way.
Old May 9, 2008 | 04:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 2 or 4 bolt main motor?
if its stock, 99% sure its a 2 bolt, if you cant get to the numbers, the only way to know is to pull of the oil pan, not a easy thing to do in the car
Old May 9, 2008 | 04:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I wouldn't lose sleep over it either way. If it's just for bragging rights, call it a 4 bolt and leave it at that.
Old May 9, 2008 | 04:39 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
my 89 iroc had a 4 bolt block in it, but it was rebuilt so i dont know if it was the original motor or not, the only real way to know is to pull it out and check cause even if u have the block number it usually says 2 or 4 bolt on the discription.....y do u ask it doesnt make it more powerful or anythin....
Old May 9, 2008 | 09:24 PM
Abubaca's Avatar
"Officially", all iron head L98 motors were two bolt, and alum. head L98 were 4 bolt. I've never seen any documentation showing otherwise.
un"Officially" several people have reported their iron head L98 motor's have had 4 bolt mains. This isn't too surprising actually. It's GM afterall.
Old May 9, 2008 | 09:32 PM
spiderhole's Avatar
Car: 86 z28 LG4 305ci
Engine: LG4 305ci
Yeah, who cares. Its stock. So much other crap will fail around the mains before its ever time to address them. The 4 bolts are just holding the crank in place if **** gets hecktic which it basically will never do witha stock engine. My CK1500 has two bolt main with headers, and exhaust, plust I floor it as much as possible.
Old May 10, 2008 | 09:55 AM
Just wanted to thank evryone for the info,the reason I was wanting to know ,I'am gonna drop a 383 with a carb in it and a friend of mine wants to buy the motor.I know that a 2 bolt's not gonna hurt anything ,but he's 17 and everything's gotta be a 4 bolt.
Old May 10, 2008 | 10:09 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
The simplest way is write down the block numbers and then look on Mortec.com
Old May 10, 2008 | 01:10 PM
spiderhole's Avatar
Engine: LG4 305ci
Yup, check the number
Old May 10, 2008 | 01:31 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
aparently yall have never used this feature, most of them say 2 or 4 bolt mains.......so even then u still have to pull the pan.....that is the only way to know for sure....
Old May 10, 2008 | 04:05 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Maybe the one that matches up to his block number doesn't say 2 or 4 bolt. I would rather him do a simple check on the numbers vs. pulling an oil pan. If it were my car/engine, I would want to know the numbers regardless.
Old May 10, 2008 | 04:38 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
im just stating there is only one way to be sure and that is to pull the pan, if hes gonna build a 383 hell have to pull the pan too, i doubt he has one of the rare blocks that are listed as 4 bolt only.....ive had countless 350 blocks and everytime i run the number it says 2 or 4 bolt mains....i just use the mortec info now to identify the stock cid of a block....its a 2 part process in my opinion, look at number then pull the pan, 1 with out the other is only a half truth....
Old May 10, 2008 | 06:26 PM
Nsomnia's Avatar
Note to him splayed 4 bolts (aftermarket) are much much stronger than 2 bolt or factory straight 4 bolt caps.
Old May 10, 2008 | 08:15 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
My buddy picked me up a 350 motor, I checked the numbers and then pulled the pan to verify. Turned out to be a 4 bolt. He later told me it was out of a Chevy bus.
Old May 10, 2008 | 09:26 PM
I appreciate all the feedback,what you guys are saying I understand,The 383 I'am building is on a 70's block as a foundation.The motor in the car is gonna get sold,I can't get to the casting #'s with it in the car.I'am just new to the third gen thing.This is my first project thats younger than I am, and plans are already in the works for a whole boatload o mods.
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
