what 4th gen parts fit 3rd gen cars?
Old May 21, 2008 | 10:06 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
I'm curious as to what parts are simple swaps from a 4th gen car to a 3rd gen car because i have access to many 4th gen parts and am curious as to if i should try and use any of them on my third gen car?
Old May 22, 2008 | 01:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what 4th gen parts fit 3rd gen cars?
The entire rear suspension, springs, shocks, lower control arms, driveshaft, the rear end bolts in but its 2 inches wider on each side. The 93-97 rear brakes are the same as the 89-92 rear brakes, but I think the emergency brake cables are different. Certain LT1 engine parts are the same, like the pistons, rods, crankshaft and camshaft, but not the heads or intake. The LS1 is competely different and nothing fits. The wheels will fit but you need spacers first. The cat-back exhaust will fit, also.
Old May 22, 2008 | 07:45 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Front seats will bolt right up, but you'll be sitting a little lower since they are thinner.
Old May 22, 2008 | 09:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Rear seats bolt right up too.
Old Sep 16, 2011 | 01:07 PM
Lantern_21's Avatar
Car: 1991 Camaro RS
Engine: 3.18L
What about the transmission? I have a 91 3.1L with a auto trans and have access to a 95 v6 tranny will it fit?
Old Sep 16, 2011 | 07:12 PM
no
Old Sep 16, 2011 | 07:39 PM
Awesome-X's Avatar
Car: 87 Camaro
Yes. The tail shaft may be different and I'm not sure if the older transmission is controlled by a kick down cable or not but the new one isn't.
Old Sep 16, 2011 | 08:01 PM
Oops sorry, yes it will FIT, just won't WORK (4L60 vs 4l60E)
Old Sep 16, 2011 | 08:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/body...-exterior.html
JamesC
Old Sep 28, 2011 | 06:56 PM
djxxxhoodstar's Avatar
I have an 84 with drum brakes what do I have to for to put discs from a 96 on it?
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
