no oil to lifters...
Old May 25, 2008 | 05:58 PM
jabz28's Avatar
Car: 84 z28
Engine: 400 sb RIP down to a 350
Transmission: turbo 400
Axle/Gears: posi 373
well after my problem of no oil to the rockers i took off my manifold found my push rods to be clean and my lifters not to be getting any oil. i took out my lifters and tried shooting compressed air into the oil passage near the water pump this also didn't work(assuming somethings clogged) what else can i do and where are the other oil passages that i can reach while the motor is in.
Old May 25, 2008 | 09:33 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: no oil to lifters...
Was the distributor out when you tried the compressed air thing? You won't get any oil to the valve train with the distributor out. How is your oil pressure? Did it run and you didn't get oil to the rockers?
Old May 25, 2008 | 10:15 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
What leads you to believe the lifters aren't getting oil?
Old May 26, 2008 | 08:56 AM
jabz28's Avatar
Car: 84 z28
well, i forgot to mention did in another post and should have, i had the motor running a couple days ago, it has mechanical rollers and was running fine accept for the fact of no oil, figured push rods or lifters so i removed the intake manifold primed the motor with the drill, and noticed nothing coming out of th lifters so i took them out, and after all this still no oil getting to where the lifters should be. i figure a clogged oil passage? if not no idea, does the oil go through head gasket at all where maybe they sent the wrong one 2 me?
Old May 26, 2008 | 09:02 AM
jv9999's Avatar
Engine: 5.7L/350
Primed it with a drill using what? If it was just a long rod, you'll never get oil pressure to the valve train.
Old May 26, 2008 | 09:05 AM
jabz28's Avatar
Car: 84 z28
primed it using an oil pump primer, my oil gauge reads 25 psi with the drill and read 60 when the motor was idling b4 i tore it back apart.
Old May 26, 2008 | 09:35 AM
jv9999's Avatar
Engine: 5.7L/350
Did it have a full body like a distributor? There are two types.
Old May 26, 2008 | 09:47 AM
jabz28's Avatar
Car: 84 z28
got it from my neighbor, it just has the tooth and a little thing around the side of it to hold it sturdy kinda just like the bottom of dist with no teeth
Old May 26, 2008 | 11:11 AM
jv9999's Avatar
Engine: 5.7L/350
You won't get oil to the valve train with that. If you look down the hole while it's spinning, you'll see where all your pressure is going. You need one like this: http://store.summitracing.com/partde...6&autoview=sku
Old May 26, 2008 | 01:31 PM
jabz28's Avatar
Car: 84 z28
oooo, alright ill have to grab one of those. still does ne1 know the reason they may not have been getting any in the first place.
Old Jun 4, 2008 | 01:47 AM
jabz28's Avatar
Car: 84 z28
well, i got the right primer and ended up taking the motor apart, i am going to pull the cam tomorrow, thinking its a cam bearing possibly the rear, though it sounded fine when running. anyone got any ideas?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
