valve seals change and blue smoke
Old Jun 3, 2008 | 04:03 PM
Punisher305's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 305 TPI (LB9)
Transmission: 700R4+shift kit
I got a bone stock 305 tpi with 206 000 km, I know that my valves seals are worn and there is a lot of blue smoke everytime I start it or When Im leaving a red light (after a least 10 to 30 secondes). what can be worn too other that my valves seals?
Tomorrow, my camaro is going to the garage to change the worn valves seals, I've bought felpro valve seal number: SS72577 and SS72877, I just want to be sure that this gonna fit, someone know that?
Thank you very much
Punisher305
Old Jun 3, 2008 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What else could be worn? Valve stems or valve guides.
Couldn't tell you about the valve stem seal p/n's.
Old Jun 3, 2008 | 06:07 PM
Re: valve seals change and blue smoke
maybe valve guides or piston ring?
Old Jun 5, 2008 | 12:14 AM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
kinda tha same
befor i put my 350 in i lubed up the rocker arms (valve train)cuple weeks ago and now i noticed one exhust ports turned wet lookin from normal dry black(used 350)
Old Jun 5, 2008 | 05:48 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Use Fel-Pro SS72527 on both the intake and exhaust. They are positive type Viton.
Old Jun 5, 2008 | 02:00 PM
Car: 83 Camaro
Engine: 5.0
so i have a leak and wanna change em all
my camaro is a 83 two piece RMS 305 5spd mech.clutch
new engine is a 76 2pc RMS 350
Fel-Pro SS72527 not gunna do it dont think
Old Jun 7, 2008 | 05:51 PM
I change them wednesday and the valve seals fit perfectly, And now, there is no smoke when I start it or when I leave a red light!
Last edited by Punisher305; Jun 7, 2008 at 06:00 PM. Reason: Automerged Doublepost
Old Jun 7, 2008 | 06:03 PM
the parts is SS72527 and SS72877
dkillacamaro: I think they will fit
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
