intermittent starter issues... bad connections/grounds?
Old Jun 18, 2008 | 11:14 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
this has been ongoing for a little while now, but it is becoming more importiant as it gets ready for the race season.
every couple times i crank the car i get the god-awful clicking sound like the battery is low, but i will do it again and it will crank normally.
i am thinking bad ground/connection... does that sound right?
what exactly is happening when that loud clicking occurs anyway??
Old Jun 19, 2008 | 06:00 PM
impaled's Avatar
Re: intermittent starter issues... bad connections/grounds?
i dont like to bump my self... but i would like some guidance.
Old Jun 19, 2008 | 06:03 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thats very possible, or it could be heat soak, do you have long tubes? i do, and i get heat soak frequently,
Old Jun 19, 2008 | 08:35 PM
impaled's Avatar
i have not found a clear definition of heat soak, so if somebody could explain it better that would be great.
i do have long tubes, but this is happening at a cold start.
i havent had it all the way up to temp after everything due to my pulley issue (misalligend v belt), my serpentine conversion kit is shipping out from summit on the 28th.
Old Jun 21, 2008 | 02:51 PM
impaled's Avatar
i have checked grounds... any ideas?
Old Jun 21, 2008 | 07:55 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well if it happens at a cold start, the heat from your long tubes could be frying your solinoid. heat soak is when the electrical component gets so hot it doesnt work, because it has too much resistance, caused by the increased temperature. after a while, it'll do lasting damage. if its heat soak, get a new solinoid, or get a new one and relocate it to the fire wall, there is a kit for it at summitracing.com i think
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 03:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
