Getting no codes
Old Jun 19, 2008 | 02:53 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Getting no codes
So, I plugged in a paper clip into the ALDL connector in the A and B teminals in my 92 Camaro, waited like 2 minutes for codes and I did not get any. According to the FAQ, it's defective and needs to get replaced? How could this be?
Old Jun 19, 2008 | 06:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you turn the ignition switch to "on"?
Old Jun 19, 2008 | 07:04 PM
92 Camaro's Avatar
Re: Getting no codes
Yes. I followed the directions on Vader's post here. https://www.thirdgen.org/forums/tech...ce+soon+engine
Old Jun 19, 2008 | 07:34 PM
five7kid's Avatar
Make sure you're getting the paper clip into the terminals, and into the correct terminals.
Is the SES light coming on during operation?
Old Jun 19, 2008 | 07:57 PM
92 Camaro's Avatar
I am putting it in the correct terminals. The SES light its supposed to go through that pause-flash process and then show codes, but it never shows the codes.
Old Jun 19, 2008 | 09:20 PM
five7kid's Avatar
Is there a problem you're trying to chase down? Does the SES light come on when you are driving it?
Old Jun 19, 2008 | 09:21 PM
92 Camaro's Avatar
Yup, it stays on.
Old Jun 20, 2008 | 08:50 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
that was the problem with my '87 (SES always on and no codes). i determined that the computer was dead after some meter readings. if that is the case, the SES is on as a failsafe when the computer is dead. i would check to make sure there is power to the computer.
Old Jun 20, 2008 | 10:40 AM
92 Camaro's Avatar
Damn. So what do I do? Would getting it scanned with a ALDL scanner make a difference?
Old Jun 20, 2008 | 02:38 PM
impaled's Avatar
as long as you are jumping the right terminals a scanner would be no different.
what you should do is to test for power on the computer. from what i remember about mine is that there is a fuseable link between the battery and the computer, so you might want to check if that is blown. you should also check all of the fuses to see if any are blown.
Old Jun 20, 2008 | 02:41 PM
92 Camaro's Avatar
You mean a fuse in the fuse block under the drive side dash?
Nevermind...fusible links...something i cant do. I have no idea how to do what you just said.
Old Jun 20, 2008 | 02:53 PM
five7kid's Avatar
Should be a fuse, not a fusible link.
Old Jun 20, 2008 | 03:05 PM
92 Camaro's Avatar
Ok, I looked in my handbook and there is a fuse for the Computer Command Control-10 amp(which i have to get) and then ECM crank unit-3 amps. Should I replace that one too?
Old Jun 20, 2008 | 05:52 PM
impaled's Avatar
only replace fuses if blown. then grab the volt meter and start getting some readings off of the computer.
Old Jun 20, 2008 | 06:02 PM
92 Camaro's Avatar
Ok, neither of the fuses i mentioned are blown. You want me to stick the voltmeter in both of the terminals?
Old Jun 20, 2008 | 06:56 PM
impaled's Avatar
no, into the terminals/wire on/to the computer. check out some good wiring diagrams first though. you want to figure out which wire powers the ECM
Old Jun 21, 2008 | 05:48 PM
92 Camaro's Avatar
Could you point me into the right direction with this diagram and where I need to test?
Old Jun 21, 2008 | 08:07 PM
impaled's Avatar
my service manual doesnt have the diagram for the TPI motors, but if you find one the wire you need is the wire that powers the ECM. you are going to need to unplug the harness from the ECM and test the wire that powers it. if you found the fusable link it should be the same wire so you could follow that.
Old Jun 21, 2008 | 08:12 PM
92 Camaro's Avatar
Well I have the TBI. Does that make a difference? Because I looked in my Hayne's Manual and it only had the diagram for Engine Control System 5.0 and 5.7 TPI.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
