head casting info
Old Jun 29, 2008 | 11:39 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
head casting info
my heads are 14101081 can anyone give me the specs on those? what cc size and valves were used?
Old Jun 30, 2008 | 12:03 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: head casting info
1986-91 305 heads. 1.84 intake, 1.500 exhaust.
Old Jun 30, 2008 | 02:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Actually they're 87-92 heads. Valve sizes are correct 1.84"/1.50". And the combustion chamber size is 58cc's.
Old Jun 30, 2008 | 09:46 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
they are pretty good heads for a 305 and a nice punch for a 350 with bigger valves
get a cam under 470ish lift and put a set of z-28 springs in there with a good exsaust and intake and bam
you will blow it up in a week and build a 350
Old Jun 30, 2008 | 09:56 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Again he could do his research and work his heads into a 350 build without the bad timing of blowing his motor first though right?
Old Jun 30, 2008 | 01:44 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
the ole lg4 has already been shot. she might be salvagable. however, i already have a 350 bored over 60 (the cylinders were that bad) that will be going in it place just was thinking about reworking my heads and adding them into the project instead of buying brand new ones
Old Jun 30, 2008 | 02:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There's more to heads than just combustion and valve size. Intake runner size determines how much air gets sucked into the engine. Restrictive ports means no air for bigger engines that need it.
There's only a small handful of 305 heads that can feed enough air into a 350+.
Old Jun 30, 2008 | 03:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Factory 305 heads that will feed a mild 350 well: 601, 416, 081. They have the same port sizes as iron L98 heads. 1.94" intake valves, and 1.60" exhaust valves if you like, with basic port/bowl clean-up, will easily support a 350 HP 350.
Old Jun 30, 2008 | 06:01 PM
jamon8's Avatar
Engine: 350 tpi
I have factory heads- I want a car lenth
I have factory runners-another
I have a factory intake-another
the lift on my cam is under .5-who cares
no stall-I am just gonna keep listin
2.77 gears
I will make you feel silly for spendin the money all the way to 160
oh buy the way for those of you who say my car hits the traps at 120 you will be lookin at my tailights
naturally asperated
just had to let it out
every once in a while a man has to let them hang
junkcltr
Aug 2, 2019 11:12 PM
Cornholio7979
Sep 20, 2018 02:31 AM
509 camaro fan
Sep 6, 2015 10:43 AM
camaro71633
Sep 1, 2015 10:24 AM
ambainb
Aug 29, 2015 12:43 AM
