how much base timming?
Old Jul 1, 2008 | 04:31 PM
kevinm1980's Avatar
i have a 185 transam 305lg4 canadian model(non-ecc), later this summer i am dropping in a 350, but i recently put some botl-ons on the 305, header edelbrock performer 2101 manifold, edelbrock 1405 carb, and upgraded the coil and module, my question is where should i set the base timming, right now it's stock at 6btdc, it runs fine, but wondering if advancing it or retarding it will make a difference? any input would be helpfull
Old Jul 2, 2008 | 08:03 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: how much base timming?
What is your max timing (with full mechanical advance)? You want that to be 36°. So, if you're only around 32° or so, you could bump up the initial timing another 4°, which would make the max timing 36°. Here are some good references to be familiar with.
timing article #1
timing article #2
timing article #3
Pac J
May 17, 2020 10:44 AM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
timonator
Sep 17, 2015 06:57 PM
