i need a cam :help:
Old Jul 10, 2008 | 05:26 PM
cashfella's Avatar
Car: 88 Camaro. 99 Grand am.
Transmission: t-5
Axle/Gears: 3.08
i need a cam :help:
i want to put a cam in my 1985 camaro irocz/z28... it has stock lg4 engine with no other peformance work and 700r4 tranny with a stock converter... please help decide what cam to go with..... i want a nice sound but still keep my gas mileage. Also i dont want to spend a lot of money but i want to buy a cam thats worth it... give me some ideas for my daily driver
Old Jul 10, 2008 | 05:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: i need a cam :help:
If you're not doing any other work to it, try a Comp XE262.
Old Jul 10, 2008 | 05:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I edited your thread title because it was in violation of the Board rules you said you read and agreed to when you signed up.
Let's not see that sort of thing again.
Old Jul 12, 2008 | 10:09 AM
cashfella's Avatar
Transmission: t-5
Axle/Gears: 3.08
thanks
Old Jul 12, 2008 | 10:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A cam is the last thing you need on a stock engine. With all the other little things you "should do" while the intake manifold is off, a cam swap just snowballs into a huge project. Plus you will not gain much from it when you stil have the stock intake and exhaust on it.
You should start with subframe connectors. That will really stiffen up the chassis and make it handle better. Then go with a cat-back exhaust, aftermarket catalytic converter, and then headers.
Old Jul 12, 2008 | 10:37 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
cheapest way with the most new parts and the most performance for the buck and keep it streetable in my opinion
rv cam and lifters
1.6 roller tip rockers
z-28 springs
Old Jul 15, 2008 | 07:19 PM
blp226's Avatar
Instead of changing cams, put some roller rocker arms, headers, intake and carb. A cam by itself tends to steam roll into a big project and it won't help with out the other stuff anyway. If you feel you absolutely must change the cam, give Comp Cams tech line a call. they can give excellent advice.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
