what kind of engine is this
Old Jul 12, 2008 | 01:26 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Recently purchased a 87 camaro which had the motor swapped and I'm puzzled as to what the motor is. The engine stamp is V0429CLT which says its a 73 350. However the engine is nearly twice the size of my 305 and as I know the 305 and 350 share the same block. Not only are the heads width an extra 2 inches but it has center valve bolts which lead me to think its newer. This is way to confusing, do I have a frankenstein motor?
Thanks guys
p.s. didnt mean to add the smiley lol
Old Jul 12, 2008 | 01:42 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: what kind of engine is this
How about putting a photo of that monster up??? Also take a look at the block and heads casting numbers. 305 and 350 and for that matter all first gen SBC share the same exterior block dimensions - hence great interchangeability! Also, all 1st gen SBC have siamese 3&5 and 4&6 exhaust ports. If your monster is different you do not have gen 1st gen SBC.
//RF
Old Jul 12, 2008 | 01:47 PM
the casting number i provided is the number thats hidden by the alternator casted into the block. is there another number stamped on the block somewhere? something else I can go off of?
thanks
Old Jul 12, 2008 | 01:50 PM
RFmaster's Avatar
Car: 75 Beast
V0429CLT is a production order number - equipment specification and it is not a cast, but stamped with die punch. FWITW get a photo up a lot easier to ID that way.
CU
//RF
Old Jul 12, 2008 | 02:28 PM
here are three pictures 2 of them are the motor and one of them is my 305, you can see the dirty one(the frankenstein motor) is clearly bigger lol, im pulling it out probably tomorrow
Attached Thumbnails what kind of engine is this-0712081516.jpg   what kind of engine is this-0712081517c.jpg   what kind of engine is this-0712081517a.jpg
Old Jul 12, 2008 | 02:50 PM
ls six's Avatar
looks like an sbc with late center bolt heads.
All sbc's should be the same size but aftermarket blocks can be had with a taller deck that'll make the whole motor wider.
Old Jul 12, 2008 | 02:57 PM
eek. this is getting bad... the guys i bought it from said the original owners took the motor out of a junker. Is there any numbers on the block that would identify it properly besides the CLT one i found?
Old Jul 12, 2008 | 03:09 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
behind the drivers side head on the block is the number you need.
www.mortec.com
Old Jul 12, 2008 | 03:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
CLT is a 73 350 block. It's not hard to put center bolt valve cover heads on an early block.
Getting the casting number from behind the driver side head will probably only indicate that you have an 010 block.
Pulling a valve cover to get a head casting number will give information about the heads.
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
