MY 85 IROC will not idle
Old Jul 17, 2008 | 06:42 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
My car does just fine while driving with the exception of the surging it gets while i'm coming to a stop and have let of the gas or it is idling. and occasionally while i'm giving it just a little gas.
I'd like for some explanations on this phenom.
as for what i know, it does not have a blown head gasket, doesn't smoke no mily oil etc.
i just replaced all the plugs and i'm just very confused.
I'm curious what could make this car idle so bad and surge like it does, I'm aware that the 85 IROC's were a mess in the electircal dept as well as the comp they used. but i love the car it is a 305 tpi if it helps. HELP ME
Old Jul 17, 2008 | 09:10 PM
IROCthings's Avatar
Axle/Gears: 3:73
Re: MY 85 IROC will not idle
anybody? i'm told it could just be as simple as a timing issue does that sound correct?
Old Jul 18, 2008 | 01:40 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
To set the timing the ECM spark control has to be disabled, or you'll never get it timed right. Different models diabled it differently so check your specific model's manual.
Disable the spark control, start the engine , if it still surges it's not the timing.
Look for vacuum leaks, or carboned throttle body, especially the Idle air passage. if you do clean it up the IAC will need to be reset.
Old Jul 18, 2008 | 02:13 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Check minimium idle air setting.
Red iroc-z 305
Sep 30, 2015 05:22 PM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
