where to buy a fuel tank sending unit??
Old Jul 28, 2008 | 05:06 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
I have a 1987 Iroc that needs a new sending unit. I went to napa and they can not get one for the car. classic industries wants 658.00 for it and paddocks wants 597.00 for it. Anywhere else to try?....
Old Jul 28, 2008 | 09:43 PM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
Re: where to buy a fuel tank sending unit??
if you have a local mom & pops style auto parts supplier..i get either an Airtex or Denso one...both are pretty reliable. I know i kinda need a sending unit myself but i end up buying a pump only a few years ago...if i was smart enough i would of bought the whole assembly unit with strainer. (and no they ain't cheap)....Whenever you replace fuel pump sending unti assemblies they're always gonna be expensive...regardless where you buy it from...
Old Jul 28, 2008 | 10:37 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Wow!! Expensive!! Autozone has the sending unit (Fuel level sender included) For something like 150.oo Checker (Schucks, Kragen) Should have it for around the same price. If you have any trouble finding it pm me and I will get you a part #. Good luck!!
Old Jul 29, 2008 | 06:07 AM
NY87Iroc's Avatar
I checked autozone and checker, they both have the same part number and have a harness code of "FPH"...My harness code is "FEU"
Old Jul 29, 2008 | 01:44 PM
NY87Iroc's Avatar
Well I ended up ordering one from GM...
Old Jul 30, 2008 | 04:56 AM
Yeah, my car is tpi so It just plugs right in... That sucks man...
Old Jul 30, 2008 | 06:43 AM
NY87Iroc's Avatar
Mine is tpi also....
Old Jul 30, 2008 | 08:27 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Cancel if you can. www.rockauto.com I got a tank and sending unit assembly from them a few months ago.
Old Jul 30, 2008 | 10:29 AM
NY87Iroc's Avatar
I just looked and its the wrong harness code...I can get the same one at napa. My harness code is different, Mine is FUE and that one is FPH.
Old Jul 31, 2008 | 03:04 AM
I replaced mine with the one from autozone and everything plugged right in. No problems. If you like I can probably get you a part number... Never even knew there was more than one sender assy..... I also used a walbro pump with mine so I had to cut the harness in the tank....
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Irocohio
Aug 12, 2015 08:03 AM
