Headgasket installation
I'm about to install my head with a .015 shim gasket from felpro. If you look at the gasket from one side, the word "felpro" and the part number are both right-side-up and there is a raised ridge all around every hole the gasket is supposed to seal. If you turn it so the felpro is backwards (orplef), there is a valley around every hole the gasket is supposed to seal. Which way should be facing the head? The raised ridge or the valley? I assume that the raised ridge faces the head, but i wanted to be sure
cheers
cheers
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Headgasket installation
I installed mine "felpro" with no problems.
You may want to use copper spray-a-gasket on both sides of the shim for extra sealing qualities.
yeah - thanks - my block and heads are smooth within 30 microns or w/e it was measured in - wont need the spray gasket - but i do have some of it and an extra set of gaskets just in case
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I allways put the gasket up. where you can read felpro as you look down. You can not put a small block head gasket on upside down. It will run either way.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Always install the gaskets so you can read the words.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hey guys, i was just about to buy this .015 Felpro 1094 and i noticed it says it has a 4.10" Bore, what the hell! aint the 305 a 3.736" bore?
anybody to clear that up for me? would be great, thank you!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Doesn't matter ownor. The bore of the gasket is always larger then the cyl bore.
Usually a 350 chev gasket has a 4.166" bore too... one size fits all sorta thing.
Car: 92 GTA/ 00 TA
Engine: 383/350
Right.
If you get that gasket, it'd be a good idea to spray both sides of it with copper spray-a-gasket adhesive.
Engine: LS1 / L03
yep okay, thanks for your replies! so i guess i'm going to get that one to bump the CR a bit - oh one more question, does the HG's bore size also contribute to a change in CR or is it really just the compressed thickness?
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Gasket bore diameter is taken into consideration in calculating CR. It's apparently important enough for them to include it on the Keith Black compression ratio calculator web page.
http://kb-silvolite.com/calc.php?action=comp
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
bore size and thinkness are added into CR on the gaskets
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes the bore size of the gasket matters (if you want accurate math)
I always install this gasket clean and dry on a clean and dry block deck.
No spray, goop or sealer of any kind.
Never had one fail even with over 12:1 cr.
If you want to do something that will contribute to a better head gasket seal, buy a new set of head bolts.
Car: 92 GTA/ 00 TA
Engine: 383/350
I always installed clean and dry as well.
Several people on here suggested to me to use the spray due to that gasket being such a thin shim gasket. I've had no problems with the spray on this particular gasket.
gixxer92
Sep 1, 2015 04:32 PM
