Fuel ECONOMY: Running V8 in 4 cyl. How do it?
Old Aug 1, 2008 | 04:15 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hey guys:
I'm thinking if I can run a TPI V8 in city with 4 cylinders only. What if I disconnect wires to injectors 2 - 4 - 6 - 8? I could run with cylinders 1, 3, 5 and 7? ( 8 sparks, 4 injectors = 4 cylinders working)
Then, I can put under dash an ON/OFF switch connected to 4 injectors in order to run with 8 or 4 cylinders. Or 2 switch: 1 for injectors 1,3,5,7 and other for injectors 2,4,6,8 and run in an alternate method.
What do you think?
Denis V.
Old Aug 1, 2008 | 04:18 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: Fuel ECONOMY: Running V8 in 4 cyl. How do it?
I think you will get worse fuel economy. The 4 injectors that you are running will probably try to dump more fuel to compensate for the injectors that are not firing. I think this sort of topic has been discussed before.
Old Aug 1, 2008 | 04:20 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I don't think your computer would like that very much.
Old Aug 1, 2008 | 04:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
NO, that won't work whatsoever. Forget that, it's a terrible idea Engineers are still working on this using much higher tech systems then that, and it's still barely feasible.
Old Aug 1, 2008 | 05:06 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
dodge does it on the new hemis, if you want fuel economy buy a 4 cylinder s10 or put an iron duke in your camaro
Old Aug 1, 2008 | 05:17 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
You need a third switch as well, for compression.... To be able to turn it on and off, otherwise the 4 cyls will be working twice as hard.
You figure that one out, ull be rich.
Old Aug 1, 2008 | 08:12 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Hmm, I never thought of that. That is a huge issue, I suppose.
Even with DOHC engines and the like, you still build up compression.
Do any vehicles have some type of solenoid driven valves?
Old Aug 2, 2008 | 02:21 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
This is true. 2 of my plug wires fell onto my headers without me knowing and I started to guzzle a lot more gas than I normally do and when we checked, boom, two plug wires compeltly gone. Not even firing off the plugs, so with the lack of my two cylinders firing, a lot more gas was used to compensate.
anesthes
62
Jul 9, 2017 01:39 AM
dennine3003
Nov 10, 2005 12:26 AM
black88ta
Feb 14, 2004 10:32 AM
87transam5.7tpi
Theoretical and Street Racing
23
Nov 10, 2002 11:39 PM
gonzo350
Oct 4, 2000 10:42 PM
