Engine rough at certain RPM's...help!
Old Aug 16, 2008 | 07:24 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Hey guys,
My bird has always had the problem of being quite jerky from around 1300-1700 rpm and most noticably in the first three gears, less in fourth and non existant in overdrive.
You can really feel a "chugging" and you can hear it too, its very annoying and I want to get it fixed before I sell the car.
Also, especially in the first two gears, when you are cruising or accelerating and you suddenly let off the gas, the car almost feels like its braking, it really sputters and decelerates quickly.
Its been suggested to me that bad injectors are the problem, and my Haynes manual lists like 10 different possible causes, looking for some suggestions!
Thanks alot,
Cam
Old Aug 16, 2008 | 07:28 PM
CroakMan's Avatar
Re: Engine rough at certain RPM's...help!
my 2.8 does that
Old Aug 17, 2008 | 04:50 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Anyone with some ideas? Need this fixed!
Old Aug 17, 2008 | 04:58 PM
TransAM Joe's Avatar
Do a good tune up: plugs, wires, dis. cap and see what happens.
Old Aug 18, 2008 | 10:58 PM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
You might try the Throttle position sensor (TPS). Not uncommon for them to develp a bad spot noticable at a certain rpm. You would notice it most under acceleration which might be why you notice more in the lower gears. It can be checked with simple multi meter.
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
