Does this stuff work?
Old Aug 22, 2008 | 06:41 PM
BladeX10's Avatar
Car: 1991 RS v8
Old Aug 22, 2008 | 07:41 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Does this stuff work?
havent used it personally but i wouldnt bank on it. Something you buy from checker for 8 bucks is most likely not gonna be a cure-all for your motor troubles, does your motor show signs of decreased performance? id start with the basic tuneup and work from there but dont put your bets on an addative that claims to fix your motor with one use, people do the same with that autorx stuff but i dont personally wanna spend the money to get no results. The product you listed just looks like a regular old motor flush so you might not gain anything unless you have tons of miles on it, in which case you should get some seafoam, mine just ran over the 200K mark and i de-carbed the motor with seafoam and noticed a bit of lost power but not a whole lot. Smoked like crazy though that was the fun part
Old Aug 22, 2008 | 07:48 PM
BladeX10's Avatar
Car: 1991 RS v8
No decrease in performance.. Just found out it had 217,000 miles instead of 117,000 so i thought id go pick some up since ive heard alot of recommendations for this stuff from people.
I was looking for sea foam but i couldnt find it.. Where do i get that stuff at? lol.
Old Aug 22, 2008 | 11:49 PM
ParkerTPIz's Avatar
pretty much none of those "engine restore" products work.
if your motor has tons of miles on it, and u want to fix it, itd be best to look into a complete rebuild or motor swap.
although an engine rebuild is pricey, it is worth it in the long run. and besides those products will just cause you headaches anyway,
Old Aug 23, 2008 | 12:24 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well for those of us not dripping with cash...
Seafoam did the trick for me , DO NOT use it in the crank case. i put half in my fuel system and half into my TB, shut it off then give it 5 or 10 minutes then crank it, stand back cuz it smokes but at best it just de-carbs im in the same boat, mine just rolled for the second time im at 20350 (i think thats the number two hundred thousand three hindred fifty miles. AND its already had a swap before that lol.
Seafoam is good stuff should be able to get it at any parts store, checker/shucks/kragen, autozone, o'rieleys etc
Old Aug 23, 2008 | 12:36 AM
BladeX10's Avatar
Car: 1991 RS v8
Id rather get every last bit out of this engine. Im very poor right now.. I would like to make it to atleast 250,000 miles.
I would have never known it had over 200k miles on my engine if it wasnt for carfax. It still runs pretty good.. But i think it needs a nice eternal cleaning and tune up
I'll have to go check out auto zone and kragens soon for sea foam.. I heard good stuff about that too.
Id have to wait until i have the car over at my other house in the country since i'd probably smoke out this whole neigborhood with seafoam.. lol...
Old Aug 23, 2008 | 12:51 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
what is the car doing? is it using oil if so how much and how many miles dose it take to use a quart?
do the gaskets leak if so wich ones?
Old Aug 23, 2008 | 01:02 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
It's just 90 wt. oil. Thickens everything up so it doesn't leak or smoke. Use it when you sell it.
Old Aug 23, 2008 | 01:07 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
i think his car isnt using oil up i think he just wants to breathe a little life into the thing so it doesnt break down on him, im in the same situation going to college full time and working 32 hours a week is kinda takin up my money and time lol when things free up my money all goes into my cars
Old Aug 23, 2008 | 01:19 AM
BladeX10's Avatar
Car: 1991 RS v8
I believe this engine wasn't really cared for.. It has so much built up oil and stuff on the outside of the engine.. Im about to give it a real good degrease job soon.
Only gaskets that leak are the valve cover gaskets.. thats because the covers are all bent and dented.. I got some chrome ones sitting here. It burns alittle bit of oil on idle.. but other then that.. its a pretty healthy engine.
This is going to be my semi daily car. I know it has some life left it in but it just needs a good seafoam clean and stuff
Old Aug 23, 2008 | 01:30 AM
Rick King's Avatar
Car: 1987 TA
I would only treat the inside with a safe for your sencer motor fluch.. if you degrees it you will probly have a lot of leaks Like I did on a 350 that had 170,000 miles on it just my 2 cents take it or leave it
later
and
GB
rk
Old Aug 23, 2008 | 01:41 AM
bigboy123's Avatar
Those things do work, but it wont really give you noticeable effects,they just thicken up your oil, and they arent meant to "save" your engine. with that many miles, your best bet is a rebuild
Old Aug 23, 2008 | 02:45 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
you kinda gotta pick your poison at this point if you degrease you MAY find some leaky spots because the sludge and dirt mixture thats sealing the leaks will be washed away just degreased my 02 lancer with 92k miles on it cuz the valve cover was messed up i replaced it but when i degreased the intake started to develop a leak so its kinda of a swing or miss with it, hope it helps
Old Aug 23, 2008 | 03:29 AM
BladeX10's Avatar
Car: 1991 RS v8
So should i just leave it for now? Im not too picky about the engine.. just thought id wash off the caked up sludge
Old Aug 23, 2008 | 12:14 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
id say just leave the clean look for a new motor if and when you get one
Old Aug 23, 2008 | 12:40 PM
Kevin84Z28's Avatar
Leave it, lots of things go "funny" if you're not careful. If you do degrease the motor, use a spray on degreaser and a LOW pressure hose. Cover your distributor cap with a piece of plastic. Too many times a high pressure hose is used, like at a car wash. It does more damage than good.
Old Aug 23, 2008 | 02:53 PM
BladeX10's Avatar
Car: 1991 RS v8
I just mainly wanna clean off the intake manifold and alittle bit of the crusted oil off the exhuast manifold
Old Aug 23, 2008 | 03:30 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
go for the Black Magic Engine cleaner -$5 a can on a warm engine and low pressure water spray (less water is better) - best product doesn't ruin rubber hoses or electric connections
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
