new motor woahs
Old Aug 23, 2008 | 11:00 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
new motor woahs
alright so i got my new 350 in. everything works except it overheats. now i have the fan plugged in and it comes on. the waterpump and thermostat are new. i heard that if the catalytic converter is plugged that will cause it to overheat is this true? or if not what else could cause my engine overheat.
Old Aug 23, 2008 | 11:13 PM
bigboy123's Avatar
Re: new motor woahs
Could be a coolant leak, bad heat conductivity in the engine, not enough air flowing through the radiator, slipping fan clutch, also check your lower radiator hose, water pump impeller, and your radiator cap
Old Aug 23, 2008 | 11:17 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: new motor woahs
is the air dam on it? without it ,it will heat. have you checked radiator to see if its stopped up? are you running a water/antifreeze mix, straight water will make it heat.let it run intil it reaches operating temperature, turn it off and see if top hose is hot, if not thermostat isnt opening.hope this helps, jimmy
Old Aug 24, 2008 | 07:22 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: new motor woahs
theres no leaks. the impeller is good its a brand new water pump not a reman. i'll look at the radiator to see if it flows at all. but i put a new thermostat in it not to long ago. i used the same intake that i had on my 305. maybe i'll just replace my thermostat and put on a flex fan instead of a regular one
Old Aug 24, 2008 | 07:54 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: new motor woahs
Straight water has better cooling properties than 50/50, but the boiling point is lower than 50/50 and it doesnt have lubricating properties
New motors tend to run hot untill they are broken in.... hate to say but you may have to deal with it untill you have broken in the motor.
Old Aug 24, 2008 | 10:06 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: new motor woahs
i can never remember what year, but GM changed to a reverse rotation water pump in either 87 or 88. make sure that your water pump is the correct rotation.
i always use the redline water wetter, and have had great results with it dropping coolent temps.
Old Aug 25, 2008 | 12:05 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Re: new motor woahs
I'm pretty sure serpentine systems all have the reverse rotation pump. If your new water pump is the original style, there's your problem. If thats not the case check to see if she's running lean or if the timing is off. Definately inspect the air dam, and check all the usual suspects.
Old Aug 25, 2008 | 02:32 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: new motor woahs
its not the waterpump the block is an older block and i got a waterpump that matches the year. have any of you guys heard of drilling a really small hole in the thermostat to allow air to bleed through. i heard that today not sure if i should try that. my next question is does anyone know where this wire goes in the pic. its by the electric motor for the hatch pull down[IMG]file:///C:/Users/Owner/Downloads/0825081203_01.jpg[/IMG][IMG]file:///C:/Users/Owner/Downloads/0825081203_01.jpg[/IMG]
Old Aug 25, 2008 | 05:17 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: new motor woahs
i figured out the overheating problem. silly me i forgot to attach the postive battery cable to the alternator. now not only does the fan come on in time everything else works right. silly me oh silly me
Old Aug 25, 2008 | 06:31 PM
impaled's Avatar
Re: new motor woahs
sometimes its just the little (although hugely significant) things that can cause issues.
the good thing though is that you didnt throw alot of cash at it, and it was nothing major.
Old Aug 25, 2008 | 10:56 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
Re: new motor woahs
not to steal the thread, but there is a difference in water pumps with v-belt and serp? if thats the case then i think ill need a new wp when i do the serp setup.
Old Aug 25, 2008 | 11:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: new motor woahs
Yes, the serpentine belt setups require the reverse rotation pumps that were already mentioned. Just buy a pump for the year of the car your serp system comes off of (do not by a reverse flow though...that's only for the LT motors).
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
