How much power?
Old Aug 26, 2008 | 01:21 AM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
How much power?
What do you think i will be making for power? I am going to using a 1405 Edelbrock carb instead of the TBI soon. All mods are in my sig. All of the mods are on a L05 also. Also just for an idea waht do you think i would make if i went 383 stroker with the same motor with flat tops (like 10.5 comp ratio) Thanks again guys
Old Aug 26, 2008 | 09:29 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: How much power?
you have around 350hp if your timing is set properly. I have a similar setup with a bigger cam and a higher compression plus a performer rpm. i might be close to 400 when i get my exhaust.
My new motor is fast, but with those highway gears its ridiculous. its a turd off the line, but drop it into second gear at 65 and it pulls to 100 in like 3-4 seconds..
Old Aug 27, 2008 | 12:18 AM
v10viper04's Avatar
Engine: LT1, L99
Re: How much power?
You really think it will be making 350hp? I was told around 300 before i started the upgrade.
Old Aug 30, 2008 | 01:21 AM
v10viper04's Avatar
Engine: LT1, L99
Re: How much power?
anyone?
Old Aug 30, 2008 | 02:22 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: How much power?
350 - 360 hp, maybe a little more. It should be over 400 lbs of torque though. It will be very docile on the street too.
Old Aug 30, 2008 | 02:32 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: How much power?
a 383 needs more air flow with a different intake, a bigger cam, and is your heads stock, ported or what?? The car the way it sits will make good torque, but will be done making power around 4800rpm, as it will run out of air. Stock vortec heads need to be modified if you want to run more lift in a cam...your about at the limit of lift with the cam you have for those heads. 350hp will be pretty optimistic, more in the range of 300+ if your lucky, but if you change some more stuff around, you'll get more out of it.
Old Aug 30, 2008 | 03:01 PM
v10viper04's Avatar
Engine: LT1, L99
Re: How much power?
Its not a 383 stroker... so stroker it will be around 350hp? and they way it is now its around 300 (or at least should be)?
Old Aug 30, 2008 | 04:57 PM
Engine: L98 494hp
Re: How much power?
maybe u should dyno pull it. usually not to expensive to get a base pull, then u will know 4 sure
Old Aug 30, 2008 | 10:41 PM
v10viper04's Avatar
Engine: LT1, L99
Re: How much power?
its need to be tuned right first...
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
