Highest compression ratio on pump gas?
Old Aug 26, 2008 | 09:30 PM
Clutch-Burner18's Avatar
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 3.45 borg warner
What is the highest compression ratio i could run on pump gas with afr 195 eliminator aluminum heads and flat top hypereutectic pistons at sea level? Would 10.7:1 be possible?
Old Aug 26, 2008 | 09:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Highest compression ratio on pump gas?
Maybe. Depends a lot on the rest of the combination. You probably won't be able to run low octane but 91-92 should work.
Old Aug 27, 2008 | 12:37 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I didn't see what engine this is going to be on... 305? 335? 350? 383? 400cid?
If you've got some cam, say over 230@.050", and some decent overlap, I think with super premium fuel and a cold air intake, you could survive.
Old Aug 27, 2008 | 10:51 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
People say a static ratio of 10 for iron, 11 for aluminum. To me, that doesnt mean much, dynamic is what really matters. I'm not sure what a safe dynamic ratio is, but from what I've read, if you don't want to do the math and consider all your variables, then 10.5 seems to be the safe point. 12 can be done if you really know whats going on.
I knew a guy that was running 12:1 static in his truck with iron heads on 94 octane. I told him it was a bad idea, and the motor broke a piston after a year of daily driving. Timing advance also has an effect on the detonation.
Like Sonix said, if you've got a cam that bleeds off a little pressure, I think you'll be fine at 11.7. AFRs have nice chambers.
Old Aug 27, 2008 | 01:55 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
12.4:1 with 10 lbs of boost was my best on pump gas
Old Aug 27, 2008 | 02:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Uh huh.... I'll bet the rest of the real world would love to hear details on how you pulled that on off....
Old Aug 27, 2008 | 02:24 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i dont thnk i should have ever worked.
steel heads to boot.
i ran with 34 deg of timing and a btm to pullout timing when i was in boost.
it was a 6-71
pic
this was taken when i was tubbing it.
i made one pass on street tires and 94 pump gas
mt sportsman 31x18.5x15 and 4.56 gears
it hat a 3.3 60 ft and crossed at 130 mph. lol
i felt like john force couldent get boost because the tires would lite up
i ran it on the street for about 1 year before i sold the blower to go turbo.
the same motor was in the s10 after that on spray running 9.93 at 134.98.
so the blower and pump gas didnt hurt it.
Old Aug 27, 2008 | 02:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Tony Mamo says that here in California with 91 octane one should not exceed 11:1 cr with the AFR Eliminator heads. In my new build I will be going for 11:1 cr and a 8.5DCR.
These heads have a dual quench pad with a modern chamber that allows them to run a little higher compression. I'm currently running 10.7:1 with my older design Dart Pro One heads with no problems.
Old Aug 27, 2008 | 03:46 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
The engine is going to be a 383. Does that hurt or help my chances at making 10.7:1 cr work?
Old Aug 27, 2008 | 04:06 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Well with the same parts a 383 will have higher compression. You can do a lot with gasket thickness. Also if you use 6" rods, it makes finding the right piston harder.
Old Aug 27, 2008 | 09:01 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Actually, it helps because you can run a bigger cam than a 350 which will lower your DCR.
The people that get into trouble are the ones that do a head swap and up the C/R on a stock engine.
With the stock cam the DCR is too high.
Old Aug 28, 2008 | 02:01 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
its all about dynamic compression.. i'm at 11.1:1 with only about 7.8ish dynamic.. not entirely sure though but i'm perfect on 92 octane.. i even take her to 7k when i race..
Old Aug 28, 2008 | 09:20 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
There are some calculators online. They even get the cranking pressure right. They recommended 110 octane though with 8 lbs of boost. I'm running 93.
Old Aug 28, 2008 | 08:11 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Any suggestions on a cam? How big am i guna need it?
Old Aug 28, 2008 | 09:52 PM
Engine: 350 4BBL
We're going to need the static compression numbers first.
Deck height, combustion chamber size, gasket thickness and diameter, piston eyebrow volume.
You can plug them in HERE to get the C/R.
Old Aug 28, 2008 | 11:58 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
I'm running iron Sportsman heads on my car with 64cc chambers. According to SpeedPro I should be at 10.8 and I have to back the timing off to 22 total advance to run WOT with 93 octane. Add some octane booster and I can run 36 degree advance. I will use a thicker head gasket next time the heads are off.
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
