350 tpi stalling while driving
Old Sep 12, 2008 | 10:36 PM
MADMAXGTA's Avatar
Car: 89 TTA
So Im cruzing along then all the sudden my RPMs drop to 500,the car stays running but has NO throttle response,dead peddal,then all the sudden jumps up to 2000 RPM and slowly settles back down to normal idle, then everything is fine.This is happining periodically,during stop and go driving,never when cruzing highway,no check engine light. I will be checking my fuel filter and changing my igntion modual tomorrow,could my TPS be going bad? any input is greatly appreciated thx.
Old Sep 13, 2008 | 09:06 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: 350 tpi stalling while driving
I would change the fuel pump relay first.
Old Sep 13, 2008 | 10:05 AM
MADMAXGTA's Avatar
Car: 89 TTA
hmm,never had a bad fuel pump relay.the pump is only 6 moths old,wher is this relay at? what happins? does it just get hot and start shorting out?
Old Sep 13, 2008 | 10:38 AM
Engine: 350 4BBL
Usually the symptom is the pump doesn't run at key-on and the engine has to crank and crank until it builds enough oil pressure to close the oil pressure switch above the oil filter and energize the fuel pump. The oil pressure switch is a backup device in case the relay fails. If the O/P switch doesn't work (or is unplugged) and the contacts in the relay are bad, the symptoms you describe could result.
Here's the relay on my '88, the '89 should be the same:
I don't think it's expensive.
Old Sep 13, 2008 | 10:50 AM
MADMAXGTA's Avatar
Car: 89 TTA
THX! I oredered a relay they are a wopping 11 dollars.Yea she fires up just fine,just a touch of the key.The pressure is great usually 60 on start up and settles down to around 45 when warmed up,only seems to do this when I do alot of stop and go,turning the car on/off city driving.all the gauges read correct when this is occuring.wish I had a fuel pressure gauge inside my car to read when this is occuring...
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
