running after turning key off
Old Sep 14, 2008 | 05:22 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
this is the first time it happened ... i turn the key off and the car ran for 2 seconds... any ideas whats going on? what happened etc.....? i rewired my fan and gauge cluster but didn't not touch any ignition stuff... any help would be awesome
thanks
John
Old Sep 14, 2008 | 05:48 PM
Re: running after turning key off
bump.. this is driving me crazy
Old Sep 14, 2008 | 07:42 PM
bump
Old Sep 14, 2008 | 07:47 PM
midwest's Avatar
It the fan. Its momentum causes the dc motor to become a dc generator, back feeding power to what ever you tapped it into, my guess would be some kinda of "hot in run" source thus powering everything in that circut. When the fan looses enough speed it cant make enough power to keep it running. I bet if you turned the key off on the freeway the car would run indefinetly, untill you slowed down enough that there wasnt enough wind to spin the fan.
Old Sep 14, 2008 | 08:18 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
that is what you call dieseling.
what is occuring is that there is still some fuel in the chamber after you turn off the ignition (somehow or another) and that fuel ignites by other means than the spark plugs.
Old Sep 14, 2008 | 09:36 PM
its weird because i just started it and turned it off and it turned off fine... the fan never did that before... plus i tapped it into the fan fuse in the fuse box inside hard line like always
Old Sep 14, 2008 | 09:50 PM
midwest's Avatar
The stock set up used a relay, this would isolated the circuits from any back feeding.
Old Sep 14, 2008 | 09:52 PM
gotcha.. so basically i just need to hook up a relay to the fan switch and i shouldn't have the problem anymore.
Old Oct 19, 2008 | 03:35 PM
wulfgar the pen's Avatar
Car: 1988 sc camaro, 1986 IROC
Engine: 2.8 v6, 305 tpi (for now)
Transmission: automatic, auto( for now)
that would be the idea
Old Oct 20, 2008 | 02:18 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
A car can diesel if the idle is set too high as well I believe.
Old Oct 20, 2008 | 05:37 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
my old motor did that when it was hot because of carbon buildup setting fuel off...and being carbed that meant it kept pumping....
Old Oct 20, 2008 | 08:06 PM
LUVN'NOS's Avatar
Running crappy gas possibly? (87 octane junk)
Old Oct 20, 2008 | 08:10 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
High idle, Running to hot, or timing.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
wayshegoes
Aug 17, 2015 12:00 PM
tnrednneck
Aug 13, 2015 08:57 AM
