Which water pump to go with?
Old Sep 26, 2008 | 06:31 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I'm dropping a freshly built 305 into my 85Z and while I was at it I figured I'd replace the water pump which to the best of my knowledge, is original with 140K on it.
What I'm looking for is something decently priced but also golod on performance and reliable. I'd like it be a polished aluminum finish and be compatible with my setup like the alternator bracket and the compressor when I finally get the A/C restored.
Anyone got any suggestions?
Old Sep 26, 2008 | 10:13 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Which water pump to go with?
with a stock eng. , or mild mods. a stock pump will be fine . even with many mods. a stock pump is still good . get a new pump , clean it up , rattle can , good to go . good luck .
Old Sep 26, 2008 | 10:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you really want the polished aluminum, try the Stewart pump.
Old Sep 26, 2008 | 10:39 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I just got a pro comp aluminum pump and it was priced real reasonable.
Old Sep 27, 2008 | 01:07 AM
Car: 1985 Z28
What about this one:
http://performanceparts.com/part.php?partID=297847
It says it won't fit my year, but then at the bottom of the page It's for all smallblock chevy from 55 to 95. And all thought SBC was a universal application. So what gives :S.
Also noob question. What the difference between long and short pumps?
Old Sep 27, 2008 | 10:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's a short water pump, it won't fit with your accessory brackets. You need a standard rotation long pump.
Old Sep 27, 2008 | 09:32 PM
Car: 1985 Z28
What about this one?
http://performanceparts.com/part.php?partID=297849
The stock pulley will fit it right?
Old Sep 27, 2008 | 11:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That looks better. It should have dual bolt patterns on the hub to mount pretty much any pulley you want.
Old Sep 28, 2008 | 02:13 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Just blown out gasket(between rear plate-pump housing) at my Made in China #9240 Weiand.It was 4 month/1000km driven.Changed to guarantee.
Old Sep 28, 2008 | 04:47 PM
Car: 1985 Z28
Really!? DOes anyone else here have experience with Weiand pumps?
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
