Porting Heads??
Old Oct 3, 2008 | 04:40 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Porting Heads??
Hey guy i am going to be getting a 350 and redoing it! Now 350 heads are 1.94 and 1.5 correct me if i am wrong. But what do you guys think of porting and polishing them to be 2.02 and 1.6? Will they work good or should i buy new heads?
thanks
kevin
Old Oct 3, 2008 | 05:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Porting Heads??
Depends which heads they are.
Old Oct 3, 2008 | 06:15 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: Porting Heads??
there are some really good videos that i just stumbled across that might answer your questions. go to www.enginevideos.com or you can get them at racingjunk.com
the name of them are power building videos. he has a couple different titles.( rotating assemblies, nitrous, supercharging,,, and heads porting and valve train)
answered alot of my questions....ad gave me alot of ideas for future builds
Old Oct 3, 2008 | 08:13 PM
Re: Porting Heads??
Ok i will check them videos out sometime tonight! But lets just say that i get a 350 from like a camaro in 1968-1971?
thanks
kevin
Old Oct 4, 2008 | 09:26 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Re: Porting Heads??
there are a lot of really good castings thru those years. but even at that, just putting bigger valves in heads dont always make them flow any better. Not without some port work.
Old Oct 4, 2008 | 03:42 PM
Re: Porting Heads??
I would have a pretty good performance shop by me do it. Theny have their own funny cars and stuff so i think they will do a good job at it but is it a good idea? will they work about as good as new 2.02/1.6 heads?
kevin
Old Oct 4, 2008 | 04:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Porting Heads??
Again... depends which heads they are.
Old Oct 5, 2008 | 04:13 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Porting Heads??
It is not cost effective to pay someone else to port a stock OEM GM SBC head.
The $$$shop labour time required$$$ to fully port a OEM head to flow near a decent aftermarket head will be higher than the cost of a new aftermarket head.
A simple pocket port job "street port" "stage 1 port" will not get you up to a the flow of a aftermarket head.
The only way to do it in a cost effective manor is to do all the porting yourself and then have the shop do the valve job and other required machineing.
Be sure to get a accurate total cost estimate ( with all real labour costs, machining and parts ) before you go ahead and start this.
New high quality aftermarket high flow 2.02x 1.60 aluminum heads can be had for less than $1000 (US)
eg:
http://store.summitracing.com/partde...5&autoview=sku
What is the casting number on the cylinder heads you're thinking of having ported?
Old Oct 5, 2008 | 03:10 PM
Re: Porting Heads??
Hey thanks man ya i will run down to their shop and see how much they would charge for it! Bc i figured an aftermaket will be better but i thought i might be able to save money and have good flowing heads.
thanks
kevin
Old Oct 5, 2008 | 06:13 PM
Re: Porting Heads??
Hey guys i have found a motor that i am looking at! It is a 350 crate motor from the mid 90's he said. What do you guys think of them heads?
thanks
kevin
Old Oct 5, 2008 | 06:42 PM
F-BIRD'88's Avatar
Re: Porting Heads??
thanks
kevin
get the casting number from under the valve cover and look it up.
www.mortec.com
Most of the 350 "crate motor" heads are not worth playing with at all.
Exceptions are vortec (062 906) (350HO 330hp) and corvette L-98 aluminum (113). 350 "ZZ4"
All other heads than come on 350 cratge motors have little or no performance potential.
I get the impression your knowledge is very limited in this area.
Old Oct 5, 2008 | 07:20 PM
Re: Porting Heads??
Yes i am 17 and i think i know what i want but now im trying to some info on this stuff! Here is my plans!
350
  • bore .30
  • 2.02/1.6 heads
  • 11.1 compression
  • 800cfm carb
  • performer dual plane intake
  • small tube headers with muffler
  • high performance cam with around .600in lift on Int and Exh
Something like that and hopefully that will put me around 430-450 at the crank. Then hopefully 360+ to the wheels.
thanks
kevin
Old Oct 5, 2008 | 09:39 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: Porting Heads??
If it's a gen I crate motor (hecho en mexico), the heads are pretty much the worst you can get (then again any 76cc 1.94/1.5 smog head is pretty awful). I have a brand new pair I took off a crate motor and they are not worth running. Super low compression and really nasty lightweight castings. You can't really port these heads, there is not enough material there. If you do have a gen I crate motor, do not waste your money putting bigger valves in the heads. Start out with different (or better yet aftermarket) heads
Old Oct 5, 2008 | 10:28 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Porting Heads??
Sounds good, mabe a 750 cfm carb. and little smaller cam would help. If the heads are not vortec you would be better off buying after market heads.
Old Oct 6, 2008 | 12:42 AM
ljnowell's Avatar
Re: Porting Heads??
350
  • bore .30
  • 2.02/1.6 heads
  • 11.1 compression
  • 800cfm carb
thanks
kevin
too much cam for nearly any stock style head, too much carb for a 350. Way too much compression for iron heads. I would suggest you do some reading and study some proven combos.
Old Oct 6, 2008 | 08:21 AM
Re: Porting Heads??
Well how else would i get that much hp with a 350 and not making it a 383?
kevin
Old Oct 6, 2008 | 08:49 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Porting Heads??
You sound like you need to do a lot more research before you start building engines. A lot. Also, is this car going to be daily driven, or a track-only car? Just asking, because if 450 fwhp is your goal with a carb, you're gonna be sucking down gasoline like a fat kid chugs soda.
Old Oct 6, 2008 | 09:00 AM
Re: Porting Heads??
Ya its my every day driver but i am also getting another beater from a guy. Im having a performance shop build it im just going to buy the parts.
kevin
MoJoe
Sep 24, 2015 09:12 PM
italiano67
Aug 31, 2015 06:04 PM
Brendankup
Aug 30, 2015 01:46 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
