305 timing tab help (easy answer help pls)
Old Oct 7, 2008 | 12:27 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Ok I cant seem to find anywhere what my style marks are for timing.
Its an 87 monte ss. Lg4 I believe, cc carb'd 305. Anyway I'm trying to get the timing dialed in because it burps out of the carb when you start it but is good once it gets running. Obviously its to retarded.
My tab has 3 small humps then two large ones. Right now I have the timing set between the two large ones which I believe is 0. This is what I am not sure of. If anyone could tell me what the incriments are so I can get it to 6-8* btdc.
Also I should set it which the vacuum advanced clamped I know that. But should I set it with the parking brake on and the car in drive?
Old Oct 7, 2008 | 12:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 timing tab help (easy answer help pls)
The point of the widest and deepest notch is 0 degrees.
Old Oct 7, 2008 | 06:12 AM
Damon's Avatar
To the left of the deepest V is advanced (as you look at it from the front of the engine).
Look to the first point to the left and then the bottom of the next V to the left of that. The bottom of that V is 6* advanced.
Old Oct 7, 2008 | 10:09 AM
r0nin89's Avatar
Thank you!
Old Oct 7, 2008 | 12:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
A picture is always worth a thousand words... and I know i've gotten good use out of this picture...
https://webdisk.ucalgary.ca/~jmknopp...ming%20tab.jpg
Old Oct 7, 2008 | 02:39 PM
r0nin89's Avatar
Thank you very much guys. I got it set to 6* btdc at idle with the dizzy clamped off.
Next step is to find that damn streetfire chart and adjust my timing so its 32* advance at 3500rpms.
I seem to have lost my stupid chart anyone have a link that shows how many turns on the vacuum on the dizzy is how far to advance?
Old Oct 7, 2008 | 02:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
You won't be able to get more then about 20* of advance out of a normal can. (mechanical advance).
Which vacuum canister do you have? Turning the allen screw adjusts the rate, you use the little oval limiter to adjust the amount.
Got a great article you may want to read, thanks to Damon;
https://www.thirdgen.org/hei
PS - use timing tape (or an aftermarket balancer...), rev it up to 3500RPM, and set it at 34* or whatever you want. Lock it down. Then let the idle advance be what it is. Reset the idle screws for the idle speed you want to have.
Old Oct 7, 2008 | 11:19 PM
r0nin89's Avatar
I have an msd streetfire dizzy. I thought that the second part of the curve was controlled by the vacuum adjustment? Does that article still apply to my dizzy?
Hmmm I'm getting a little confused here. I gave my car about 7* base timing with the vacuum unhooked. I'm thinking I should give it more like 10* but do you think it would detonate on a stock 305 running 87 octane?
I'm assuming then that my MSD is weighted to give me the stock 20*. So with the mechanical advance I'm at 27* so I need to tune in to get another 5-7* from the vacuum then?
Old Oct 7, 2008 | 11:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it wants 34 degrees or so of timing when fully advanced with no vacuum advance. Vacuum advance will add additional timing on top of that.
Old Oct 8, 2008 | 10:14 AM
Damon's Avatar
Ah, an aftermarket mechanical HEI? You want to use more than the stock 6* settting of the original computer controlled distributor in that case. Probably more like about 12* initial timing. That would be the tip of the 3rd point to the left of the big V, by the way.
Set your initial timing with the vacuum advance DISCONNECTED and with it idling as low as you can get it (so the mechanical advance isn't kicking in a little bit and giving you a false base timing reading).
Old Oct 8, 2008 | 12:25 PM
r0nin89's Avatar
Alright thank you very much. I also posted up about the car bogging down at idle in drive. It almost wants to die. Any chance this is related to the timing?
And if I'm 12* advance at idle I'll still be good with 87octane?
Old Oct 8, 2008 | 12:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, that could cause the bog. Not enough 'power' at idle basically.
Timing has virtually nothing to do with your octane level needed. Set up the car to run right, then use the lowest octane level you can live with. Don't put the cart before the horse eh?
Old Oct 8, 2008 | 12:44 PM
r0nin89's Avatar
Sir I'm following your lead 12* advance when I get home from school it is. Thank you for the input I'll let ya know how it goes.
Old Oct 8, 2008 | 12:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What kind of carb are you running?
Old Oct 8, 2008 | 08:59 PM
r0nin89's Avatar
O my god. I gave it that 12* initial and the car came to life like noones business! Thank you for the advice. I'm still having odd idling problems. I believe the culprit would be running to rich as it pops out the exhaust a little now.
I'm running a mechanical quadrajet. Its the same exact looking as the stock cc one just mechanical. Not sure what it came off of. I'm trying to figure out other than the idle air bleed valves what I can adjust for the mixture. It doesnt seem like theres anything else.
My idle problem has changed in description though. Instead of bogging down very low it will now idle. If I stay sitting for a minute or two it will start to come down, and down until it dies. It definately feels like its drowning out.
Right now theres no choke on the car. I need to tranfer my old electric choke over.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
jklein337
Sep 19, 2018 06:23 PM
92purpz28
Aug 11, 2015 02:30 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
