LG4 Heads Help
Car: 1986 Iroc Z28
Engine: 305 LG4
Transmission: Borg Warner
LG4 Heads Help
I have an '86 Iroc with the 305 LG4, 5-speed. The engine smokes a little when it first start and then stops. I have been told that the valve seals need to be replaced. Also, I was told that I should find a good set of heads off a 350 and use them instead.
So hears what I am wondering:
Is there any advantage to using 350 heads instead of my stock heads?
If I use 350 heads, will i still be able to keep my emissions (since i need to in order to keep this car legal in PA.)?
When I do this I plan on replacing the cam and timing set and I need to try to keep this as affordable as I can while giving me a little boost if possable.
Any help and suggestions would be great, thanks in advance.
Jim
Jim
Transmission: 4L80E/4L80E
The LG4 has pretty go heads. As Apeiron said, 350 heads would hurt you.
On the FAQ forum there's a thread about the differences between 305's and performance improvements. Quick recap of the LG4 liabilities: air cleaner, exhaust, cam, intake manifold, valve size, in that order. Dual snorkel air cleaner, headers & full upgraded exhaust, better cam, something like an Edelbrock Performer intake manifold, 1.94" intake valves will all wake the engine up.
The majority of factory 350 heads would slow it down.
Car: 1983 Recaro Edition T/A
Engine: ex-CFI 305
Transmission: TH-700
Re: LG4 Heads Help
I'd have the same question about a LU-5 Crossfire. Sorry, I didn't find the FAQ topic...
Still looking to have decent power from my ex-CFI engine, I planned to buy Edelbrock Performer alloy heads. But, finally, I've been told they wouldn't fit because of the less-than-4inch 305 bore.
Here in France, we don't have much informations, and the mechanics that specialize in F-bodies aren't very straight...
Do someone have a suggestion ?
Thx
Thx
The LU5 had the same heads as the LG4 and L69.
The Edelbrock Performer heads will fit, they just won't give you all of the power because of the smaller 305 bore. You would drop compression significantly with them, so you might want to just stick with the stock 305 heads.
Engine: ex-CFI 305
Re: LG4 Heads Help
Wow, this is a clear and efficient answer !!!
This also means I can spend the $1700 for the heads in something else.
Well, here gas is about 8 bucks a gallon. So a late-model aftermarket MPFI seems a good idea...
Engine: ex-CFI 305
Re: LG4 Heads Help
Last thinking ( I promise
How about GMPP Fastburn or Vortec heads ?
They say they fit any 58-00 262-400 SBC. And they're required if I want an Edelbrock pro-flo fuel injection.
Both are cheap. The downside is that alloy Fastburn heads are bare, I don't know what to complete them with...
)How about GMPP Fastburn or Vortec heads ?
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
