head swap--- Please Help!
Old Oct 25, 2008 | 12:04 AM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
I have a 350 ready to to put in my 83 z28. I have a lg4 in the car now. I've read several threads saying the the lg4 heads work alot better than stock 350 heads (882 heads). I just put new head gaskets on the 350 with the 882 heads, should I pull the 882's off and put the lg4 heads on? I just put the head gaskets on tonight, the motor is still on the stand, is it ok to reuse the head gasket if i do change the heads?
Old Oct 25, 2008 | 12:07 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: head swap--- Please Help!
You might be ok. Inspect the gasket very carefully and make sure they are still very clean. The safest way to go about it is to replace the gaskets anyway, but you may be able to get away as long as there are no marks in the gasket and sealing areas.
Old Oct 25, 2008 | 12:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Change the heads and use new gaskets.
Old Oct 25, 2008 | 12:40 AM
birdtojag's Avatar
Apeiron is correct if you decide to change the heads. Should change the gaskets anyway (You only want to do the job once)
Old Oct 25, 2008 | 12:54 AM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Thanks for the replies. I think I'm going to stick with the 882 heads on the 350 for now, just incase theres a problem with the 350 when i put it in and try starting it. I'll have the 305 complete (minus carb) ready to go back in.
Old Oct 25, 2008 | 12:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd really be better off with the LG4 heads. The 882s are some of the worst of the worst.
Old Oct 25, 2008 | 01:10 AM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Whats bad about the 882's?
Old Oct 25, 2008 | 01:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're low-flowing with huge compression-killing chambers and thin castings that are prone to cracking.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
